Help me identify this shifter...
Old Jun 4, 2009 | 10:52 PM
RoccoC5's Avatar
RoccoC5
Default Help me identify this shifter...
Thought I was getting a C6 Z06 shifter, but this looks like an aftermarket shifter that fits the C6 ****. There are no markings that would help to identify it. It is spring-assisted and has adjustable shift stops. Anyone know what it is?
Old Jun 5, 2009 | 12:06 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It is NOT a stock C5 or C6 shifter. Heres a STOCK C5 shifter!
Stock on right KIRBAN on left:
BC
Old Jun 5, 2009 | 12:24 AM
RoccoC5's Avatar
RoccoC5
Hmm, it looks a lot like the Kirban...has the adjustable stops and that thin metal ring glued to the top of the base...
Old Jun 5, 2009 | 12:44 PM
RoccoC5's Avatar
RoccoC5
Old Jun 5, 2009 | 01:49 PM
ecoman's Avatar
ecoman
or a knock-off like they sell on flea-bay
Old Jun 5, 2009 | 02:10 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,,,if you took that metal ring off of it,,,it would be a KIRBAN. I love my KIRBAN! The centering springs inside the KIRBAN shifter make shifting from 3rd to 4th during a run thru the gears a lot safer.
Theres less chance to grab 2nd gear when trying to shift into 4th. The engine does NOT like 3rd @ 6000 rpm to 2nd shifts!!
Give that shifter a try!! You will like it. I dont know what that metal ring is but it looks like it can easly be removed if necessary.
Old Jun 5, 2009 | 02:20 PM
RoccoC5's Avatar
RoccoC5
Not sure what it's for either, but it's included with the shifter. Here's a pic from Kirban's site:
http://www.kirbanperformance.com/pro...%231315-B.html
Old Jun 5, 2009 | 02:44 PM
hotwheels57's Avatar
hotwheels57
Offhand, I'd say you got a good deal with the KIRBAN vs the C6/Z06 shifter. The **** is what most people like the most about the latter, anyway. The bolt on lever is a nice convenience. You can modify that lever by threading it for 9/16-18" if you want to use an after market ****. You can make adjustments with the bias springs to make that shifter as firm as you want it. If you want to lower the ****, you could machine the lever down and drill/tap another mounting point for the fastener.
When I was researching shifters for my car, it was a toss up between the KIRBAN and the B&M "Sport". I chose the latter only because I wanted the rubber isolation for noise/vibration suppression within the cabin.
To Help me identify this shifter...
