Oil Change Basics
Old Jun 5, 2009 | 04:20 PM
Millennium Falcon's Avatar
Millennium Falcon
Default Oil Change Basics
I have a couple of basic questions for a 2000 oil change. Please don't make too much fun of me!
1. How much M1 synthetic is required for an oil/filter change? Is it actually 6.5 quarts as listed in the owner's manual, or somewhat less?
2. Which Fram oil filter is preferred? Fram's choices are the basic ExtraGuard ("3x engine protection"), the middle-level ToughGuard ("6x engine protection"), or the top ExtendedGuard ("10k miles protection").
Any advice would be most appreciated.
Old Jun 5, 2009 | 04:27 PM
slothy's Avatar
slothy
i buy 8 quarts and i dump 7 in and call it a day - keep the other for top off later in the year
i use Bosch or delco filters - whatever is on sale when im at the store.
Old Jun 5, 2009 | 04:41 PM
87SAM's Avatar
87SAM
On going debate if it’s 6.5 or 7 quarts, no big deal either way. I also don’t think you’ll find much of anyone here who prefers any Frame filter.
Old Jun 5, 2009 | 04:47 PM
thisMSGgood4me's Avatar
thisMSGgood4me
The amount of oil needed can vary slightly, but generally it's around 6.5 qts. Some owners put up to 7 qts in, but you need to check how much your vette needs. I'd start with 6.5 qts, then check the level after letting the engine run for a minute or two and then off for a few minutes (to allow the oil to drain back into the oil pan).
As for the filter, I personally prefer Mobil1. My second choice would be Wix (somewhat cheaper than the Mobil1).
Old Jun 5, 2009 | 05:56 PM
TEXHAWK0's Avatar
TEXHAWK0
I put in 6 quarts, then check the level and add enough to get the level a little below the full mark.
I use only WIX filters, unless someone happens to give me a free AC Delco filter.
Old Jun 5, 2009 | 10:25 PM
TooMch's Avatar
TooMch
Use Wix or AC Delco.
Definitely stay away from Fram (for any of your vehicles)
There have been too many problems reported on Mobil1 oil filters for me.
It's your car but you asked for opinions.
Oh and what the others say about putting in 6.5 quarts then run it a bit and check level.
Old Jun 5, 2009 | 10:45 PM
thisMSGgood4me
What have you heard? Can you post any links to same?
Old Jun 6, 2009 | 07:29 AM
lar66BB's Avatar
lar66BB
Old Jun 6, 2009 | 10:24 AM
NavyVet's Avatar
NavyVet
If you haven't done this yet, remember to raise the rear slightly higher than the front or you won't get all the old oil out.
Old Jun 6, 2009 | 01:16 PM
dieseldave56's Avatar
dieseldave56
Default calibrate your dip stick Jimmy
If this car is new to you , I suggest that you calibrate the dip stick . A common practice that is often overlooked for every new engine , production or custom built is to calibrate the engine dip stick. Particulary when over filling has led to oil consumption by several pre 2001 C5 owners on this forum alone.
The practice is as simple as draining the engine's oil, R&R a pre filled oil filter ( use recommended filter) on a level surface. Add the specific amount of oil. Run the engine . Shut off engine and leave time for engine oil drain back. Remove the dip stick and note its location on the stick. If needed remark the appropriate oil level.
Old Jun 6, 2009 | 02:36 PM
Oldvetter's Avatar
Oldvetter
6.5 quarts oil. Some (later years) C5's show full at the 1/2 hash mark (normally means a quart low, this is why some people add in 7 quarts). Early years C5's show full at the top of the hash mark (normal full level). Owner's manual says you can add in another quart if going road racing (but drain it out afterwards), so 7 quarts is no big deal.
I use WIX or NAPA Gold (same filter). You can use the regular DELCO filter, it is okay and engine will go 200,000 miles with it (changing it of course). I would NOT use DELCO Premium (UPF-44) or Mobil 1, they filter too good, at cost of flow. I don't use Fram, but did years ago on other cars.
Raising rear higher than front drains out another 4 ounces of oil. You must allow extra time for the oil pan to drain (10 minutes minimum).
Old Jun 6, 2009 | 02:58 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Welcome and my compliments on asking -- better than guessing...
1. If the 'oil pan' is slightly tipped forward (higher in the rear, but not too much, as there are baffles in the pan), and allowed to drain for at least 1/2 hour -- then it will take 7 quarts.
Please note that car level does NOT equal oil pan level. I wrote-up a procedure for lifting the car which also notes the need to elevate the rear 2 jack-stand-notches higher -- or more -- depending on the oil-change location --- e.g. some garage floors are slanted more than others -- so use a level under the oil pan once jacked-up to be sure.
2. Don't use FRAM (especially -- he extraguard and extended guard) there have been many reviews/inspections/disections of fram filters to turn most off of them.
Personally, I have used Mobil-1 filters for years on all three cars (2 vettes 1 transam) without any problem -- and reviews show it to be very good -- your 2000 LS1 engine uses the 'm-107' (have same engine in our 2000 vette and transam). Available at Autozone and some wallyworlds.
btw, here's the write-up I mentioned above:
http://forums.corvetteforum.com/c5-g...ting-pads.html
Old Jun 6, 2009 | 04:54 PM
thisMSGgood4me
Not according to this particular review: Mobil 1 oil filters are fairly expensive, but their fully synthetic fiber elements do a much better job filtering small contaminants than the conventional paper elements found in cheaper filters. But despite their excellent filtering capability, these filters still flow well....They are virtually identical to the K&N oil filters
http://www.bestcovery.com/node/17184
K&N filters are excellent as well, just a bit more pricey than Mobil 1.
Old Jun 7, 2009 | 01:45 AM
TooMch's Avatar
TooMch
No links. I just have read plenty of posts over the last year and a half to 2 years to make me avoid them. It's never definite and there are always plenty of people who chime in and say how long they've been using Mobil1 filters with great success. But since there are other great filters out there, I've decided to sidestep the controversy and just buy something else.
Old Jun 10, 2009 | 10:12 PM
Millennium Falcon
Thanks for the advice, everyone. I think it goes without saying that I WON'T purchase a Fram oil filter!
Old Jun 10, 2009 | 11:40 PM
fdxpilot's Avatar
fdxpilot
One problem is on lowered cars, the nut on the filter has scraped the pavement.
To Oil Change Basics
