Speedometer on and off
Old Jun 5, 2009 | 04:21 PM
Ringerdinger's Avatar
Ringerdinger
Default Speedometer on and off
Speedometer stopped working during a strong rain storm. Cruise also quit at the same time. Thought something got wet.
After weeks of not being driven in the rain, on purpose, and kept in the garage, I am still having problems with it.
When you start out, the needle doesn't move. After 1-3 miles it will start jumping and then start working. Bumps don't seem to effect it, i.e. make it start or stop working
When you stop and turn off the ignition you go through the same thing again except it usually only takes a few 100 feet for it to start working.
Suggestions?
Old Jun 5, 2009 | 05:34 PM
timemender's Avatar
timemender
Pull, and then post the trouble codes. You may want to clear the codes and see which ones come back.
Is everything else working like traction control, active handling, all other gauges in the cluster, etc.?
The speed sensor is located on the topside of the differential.
Maybe moisture got into the electrical connector - or maybe the sensor went bad.
Old Jun 5, 2009 | 06:15 PM
Ringerdinger
I checked and cleared the codes about a week ago.
All were resolved and best I remember none were of any conseqence.
I will check them again.
Everything else in the cluster still works as well as the traction control, active handling and competition mode. I have been using the tach to gauge my speed until the speedometer starts working.
It will be late before I can check the codes. Will post them up tomorrow.
I will try to jack it up tomorrow and see if the connector is loose.
It really just acts like something isn't tight.
Any other connections to check?
Old Jun 6, 2009 | 12:19 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the connector on the top of the differential...I think.. or its the transmission. That is where the speed sensor is. Its probably corroded or lose.
Old Jun 6, 2009 | 12:49 PM
LDB C5's Avatar
LDB C5
The VSS is on top of the diff .... ask me how I know
Old Jun 6, 2009 | 08:55 PM
Ringerdinger
No codes.
I will try to check the VSS connection tomorrow.
Old Jun 13, 2009 | 07:02 PM
Ringerdinger
Anybody got a picture?
I can't find anything on top of the differential!
Jacked it up and felt around up there. Nothing I can feel and no wires except a harness coming over the top.
This is an automatic if that makes any difference.
It still is doing the same thing. Doesn't work until you go 3 or 4.
Old Jun 13, 2009 | 11:02 PM
byronhunter's Avatar
byronhunter
Default Vss
Old Jun 15, 2009 | 10:54 AM
Ringerdinger
Thanks, I'll try to get under it tonight.
To Speedometer on and off
