two hands needed for reverse!
Old Apr 14, 2009 | 11:01 PM
BCC5's Avatar
BCC5
Default two hands needed for reverse!
My 99 coupe has a B&M shifter and although the "throws" are short and positive (most of the time), I do have some problems. It seems as though I need to always be fairly aggressive in putting the car in gear especially down shifting to first. If I don't down shift to first with a firm hand I find it not really in gear and thus I proceed to embarass myself with a rather awful noise of grinding gears when taking off from the stop light! But the real test is getting this thing into reverse...It usually takes two hands and a deep breath!
It has always been an issue in the two years that I have owned the car. I recently had the clutch "master cylinder" replaced.
The shifter does not seem to be adjustable...Any clues and/or tips?
thanks,
bc
Old Apr 15, 2009 | 12:26 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I can't speak for the B&M Shifter, only the stock one. It certainly sounds like an alignment issue though with your shifter. In the case of the stock one, you put it in neutral, then loosen the locking bolt holding onto the linkage. Again, the stock one, this is done with an alignment pin lowered into the proper position first, loosen the bolt, it aligns itself, tighten the bolt back up and pull the alignment pin back up and into its storage position. Now from what I saw in regards to that pin, the shifter was straight up and centered. You might want to do something similar but suggest you mark things first so you can get it back where it is, just in case.
Old Apr 15, 2009 | 01:30 AM
sbadd99's Avatar
sbadd99
its not a alignment issue, after market shifters are stiffer, I have a MGW 15% and reverse is the hardest to engage so was the B&M before it
Old Apr 15, 2009 | 08:17 AM
slvr76's Avatar
slvr76
When my Hurst was installed going into reverse was tough. The spring tension on the Hurst can be adjusted, and it made reverse much easier. I have no experience with the B&M, so I don't know if they can be adjusted.
Old Apr 15, 2009 | 11:30 AM
BCC5's Avatar
BCC5
Hmmmm...I guess it is good that I am not alone with my shifter troubles. Next time I have the car "in the air" I will take a look and see if there is any adjustment.
Thanks for the replies.
Old Apr 15, 2009 | 11:49 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I’m changing out my stock shifter this coming weekend for a late model ZO6 shifter and will have the stock shifter up for sale if you would like to go back to stock. With the longer throw getting into reverse would be easier.
Old Apr 15, 2009 | 12:02 PM
nextime's Avatar
nextime
Venom mod!
http://forums.corvetteforum.com/c5-g...t-find-it.html
Old Apr 15, 2009 | 12:27 PM
Sinister-one's Avatar
Sinister-one
you need to align your shifter. I had the problem with my B&M Sport shifter.
Old Apr 15, 2009 | 01:03 PM
Slow Z06's Avatar
Slow Z06
make sure the reverse lockout solenoid is operating. This can be bypassed by pushing with both hands to achieve reverse. The are a common problem on the t56 transmissions, could be that yours has been bad for a while.
Old Apr 15, 2009 | 08:26 PM
TEXHAWK0's Avatar
TEXHAWK0
It also helps if you put it in 4th first and then go back to reverse.
Old Apr 15, 2009 | 10:54 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Originally Posted by BCC5
....Next time I have the car "in the air" I will take a look and see if there is any adjustment.
Putting the car up in the air may not help since you do the adjustments from inside the car.
Unless you just have an urge to climb up into the car, in that case you're good to go.
Pull the console section, then pull the radio / shifter surround.
This might help you out
Old Apr 16, 2009 | 03:16 PM
Dave68's Avatar
Dave68
Originally Posted by nextime
This mod is great for easing up the "into" and "out of" gear effort. I added a couple of .05-inch thick washers and it made a nice difference.
Old Jun 5, 2009 | 10:19 PM
BCC5's Avatar
BCC5
Default Update on my problem
OK so I put the three oil plug washers in place...no real difference. Then I figured what the heck and ordered an new B&M shifter.
I pulled out the old, after market shifter, and found that the shaft has been wearing on the "link" in the shifter base to the point that it has cut a notch!
So before I put the new B&M in I think that I will replace the shifter base and the "link" inside. Anyone know if there is an aftermarket, improved, replacement for the base/link?
Old Jun 6, 2009 | 11:47 AM
TEXHAWK0's Avatar
TEXHAWK0
What part are you calling the "link"?
Are you talking about the socket the shifter ball sets in, or the plastic part that snaps over the shifter ball?
I don't think you can buy the plastic insert separately, and you may have to buy the whole shifter to get a new base.
The previous owner did not leave out the plastic cap that fits over the bottom of the shifter shaft did they?
Old Jun 6, 2009 | 12:48 PM
dieseldave56's Avatar
dieseldave56
Default alignment
thanks,
bc
Removing the stock C5 manual shifter arm does not insure that the new B&M ( aftermarket) will match the OEM alignment specicfication.
Use the sloted shifter box's mounting holes to help with alignment.[IMG][/IMG]
When swapping out the C5 shifter assy for a C6 Z06 assy ( which includes the shift box) always mark the boxes location with scribe marks as a point of reference. With the B&M this practice would be advisable as well with your OEM C5 shift box. Loosen the shift box Torx bolts and slide one way or the other and work it back till all gears engage to your satisfaction.
Also note that clutch engagement/ disengagement tolerance may also have a bearing if this problem occurred after R&R of hydrualic cylinder.
Another note of advise is to replace the ATF with Mobil 1 or Amsoil synthetic ATF if you haven't aready done so. So many times what appears to be a "bolt in " job needs more attention.
Old Jun 6, 2009 | 01:55 PM
BCC5's Avatar
BCC5
Default thanks for the suggestions
TEXHAWKO:
The part that I called the "link" is the socket that you referred to and the plastic cap was in place on the other shifter...Now transferred to the new B&M.
The socket that you mentioned also shows wear which is why I am looking for a shifter base assembly. The stealerships only sell the complete shifter assembly!
DIESELDAVE 56:
Thanks for the heads-up on the adjustment and the fluid change suggestions.
It is a really good group of people you experienced Corvette owners are. Thank you for the information.
cheers
bc
Old Jun 14, 2009 | 10:02 PM
BCC5's Avatar
BCC5
Default final update
The B&M shifter arrived. Since the "socket" in the shifter base showed wear (like the old shifter itself) I replaced the entire base also. Put everything back together and it is like a new 6-speed!
Apparently the wear on the old shifter and the wear on the socket caused my problems. Shifts through the gears smooth and the big WOW is that reverse is simple and smoooooth!
Thanks to everybody for the help!
Old Jun 15, 2009 | 11:38 AM
nextime's Avatar
nextime
Do not set the stops for the gear shift, it may lead to very premature transmission failure, ask me I know.
To two hands needed for reverse!
