Optima Batteries, Which One?
Old Jun 7, 2009 | 05:00 PM
UBNZO6D's Avatar
UBNZO6D
Default Optima Batteries, Which One?
Which one is best for C5Z, yellow or red top? What are you guys using and why?
Thanks in advance
Old Jun 7, 2009 | 05:13 PM
UBNZO6D's Avatar
UBNZO6D
My Delco is dead now and was curious about the fuss with Optima...
Old Jun 7, 2009 | 05:19 PM
LoneStarFRC's Avatar
LoneStarFRC
Thanks in advance
Red top. Best for all 'round use as a starting battery. There are two (2) red tops. I recommend the 34/78. Much higher Cold Cranking Amps rating. The CCA rating of any battery is the truest guidepost as to the available power and the likely longevity as well. The "CA" rating is essentially meaningless, like "peak power" ratings on amps and speakers as compared to RMS power ratings.
My first one lasted right at 5 years and although it had not failed on me, I replaced it primarily as a preventative measure. As with any battery, the system voltage was gradually trending downwards over time.
HTH
Old Jun 7, 2009 | 09:59 PM
TEXHAWK0's Avatar
TEXHAWK0
Optimas fail just like any other battery.
I would just buy a ACDelco Professional 7yr battery. It has a 50 month free replacement guarantee which is as good as any in the industry.
Old Jun 7, 2009 | 10:01 PM
Drumss's Avatar
Drumss
HTH
Yup...Red Top 34/78 here too...
Old Jun 7, 2009 | 10:39 PM
c3spdrcr20's Avatar
c3spdrcr20
I have a red top. My color scheme is black/red that's why.
Old Jun 8, 2009 | 04:09 AM
dieseldave56's Avatar
dieseldave56
I used to use the red top Optimas in all my collectable vehicles but if they were drained just a few times , full recovery was hit and miss.
Now I use the Yellow Top 75/25 deep cycle batteries without any problem ( I have seven of them ). They weigh 4 or 5 lbs more but their worth it.
I pay just under $150 each and all are in a storage mode most times and use the Battery Tender Plus to keep them topped off.
The Optima batteries are used mainly because there is no acid to deal with and cell construction is heavy duty. There are all kinds of cheaper batteries and lots of options with batteries available but I prefer the Yellow Optima.
Old Jun 8, 2009 | 06:54 AM
AU N EGL's Avatar
AU N EGL
Originally Posted by 8VETTE7
Why spend upwards of $200 for a battery when you can buy a Delco 72 month battery that will last just as long and costs under $100.....
Optima, Exeedy, AC Delco are all made by Johnson Controls just differnt lines in the same plant.
get the AC Delco.
I have gone though 4 optima Red tops in 5 years. those batteries suck.
even keeping on a battery tender
Old Jun 8, 2009 | 08:18 AM
clif's Avatar
clif
St. Jude Donor '09-'10
Old Jun 8, 2009 | 09:02 AM
bobby777's Avatar
bobby777
Delco is junk==my pro series 7 year lasted 2 years--went with Optima red top 75/25 no problems for 2 years and I do keep it on a BT junior in storage--
Old Jun 8, 2009 | 09:15 AM
TEXHAWK0's Avatar
TEXHAWK0
You should have gotten a free replacement and tried it again.
You still don't know if the Optima is better since it has only lasted 2 years so far.
Old Jun 8, 2009 | 01:52 PM
B-Vette's Avatar
B-Vette
Another vote for Optima 34/78 - I WILL NOT GO BACK TO A DELCO BATTERY ON A C5 CORVETTE EVER AGAIN.
Old Jun 8, 2009 | 02:27 PM
AU N EGL's Avatar
AU N EGL
Every one likes something different.
after 4 optimas that went south, I put an AC Delco back in.
Wont use an optima again.
Old Jun 8, 2009 | 03:03 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
and here too. Mine is 4 + years old with no problems.
Old Jun 8, 2009 | 04:49 PM
molten vett's Avatar
molten vett
I use the Red Top. Bought it for my mustang 5years ago and switched it over to my vette when i sold it. I haven't had an issue and i run an aftermarket stereo.
Old Jun 8, 2009 | 04:58 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
For anyone in the market, we keep them in stock.
$105 - Red Top 34/78
$105 - Red Top 75/25
$110 - Yellow Top 34/78
http://forums.corvetteforum.com/c5-p...ops-110-a.html
Seth
Old Jun 8, 2009 | 10:12 PM
DDNZ06's Avatar
DDNZ06
Hi All,
I recently bought a Red Top as well.
What is the difference between the 34/78 and the 75/25?
How can I tell which one I got?
thanks.
To Optima Batteries, Which One?
Old Jun 9, 2009 | 12:11 AM
Oldvetter's Avatar
Oldvetter
Red Top, more CCA and 1 extra year of free replacement (longer warrenty). Use a battery maintainer when it sits 3 or more days.
Old Jun 9, 2009 | 01:14 AM
jpandes's Avatar
jpandes
I bought the Optima red top because I wanted a "sealed" battery that wouldn't leak.
Old Jun 9, 2009 | 02:24 AM
avenged_motorhead's Avatar
avenged_motorhead
I switched to optima after I found out my battery was leaking and had to do some repairs.......
