What can be done on a 4-post?
Old Jun 8, 2009 | 12:38 PM
Superman09's Avatar
0Superman09
Former Vendor
Default What can be done on a 4-post?
Hello, wondering if you can do the following work on a 4 post lift......
Drop out a rear end?
Trans for clutch install?
I'm pretty sure it CAN be done but would the 4 post cause more trouble than help? Such as maybe doing it on jackstands be easier? Thinking about picking up a 4 post lift but unsure if having it would be beneficial for the work on a C5 vette? Thanks!
Old Jun 8, 2009 | 01:01 PM
timemender's Avatar
timemender
With a four post the cradle (with the suspension still attached) would have to come out before and separately from the rear end, trans, & drive shaft assembly. Not really that much extra work. How often are you pulling the drive train?
Some complain that suspension, brake work, etc, is cumbersome on a four post. With a rolling bridge between the runways, jacking & supporting the frame to allow the wheels to hang is simple enough.
I purchased a second four post about five years after my first, because I felt the two-post would not be that much of an advantage, compared to the ease of use of a four post – driving on and off for storage, routine maintenance, polishing/waxing, etc. is a breeze.
I could have one (or two) of each style if I wanted - having a 2,400 square foot, 12-foot high garage allows me lots of options, but I find the four post models just fine.
Old Jun 8, 2009 | 01:05 PM
AU N EGL's Avatar
AU N EGL
We had my car on stands On the four post lift
Wheel were OFF and we pulled the a-arms off to put in new bushings
worked great
Old Jun 8, 2009 | 01:36 PM
Superman09's Avatar
0Superman09
Former Vendor
I had my car up on my buddies 4 post last week and we were unable to use the jack that slides between the ramps because my car was too low........
Old Jun 8, 2009 | 04:07 PM
Patches's Avatar
Patches
This is the kind of work I typically do on my and my buddy's four post lift. Never had a problem doing any job on it. Oviously a 2-poster is nice for brake/susp. work but I can do those with no problem on my 4-poster as well.
http://forums.corvetteforum.com/c5-g...mega-pics.html
Old Jun 8, 2009 | 05:29 PM
timemender's Avatar
timemender
With a four post lift and a low car like the Corvette you must find a method that works best for you in jacking up the car.
You can place 2x12 boards on the runways for added clearance.
I’ve used two 2-ton six-foot high adjustable jack stands by placing the stands on the ground under the car (on the lift) and lowering the lift a few inches to gain clearance for regular jack stands.
I have two flat (runway level) rolling platforms and a recessed sliding platform that accommodates a jack for lower vehicles.
Jacking up a car like the Corvette on a four post requires some forethought for sure, but once you figure out the best method for you, it's not bad at all.
Old Jun 8, 2009 | 07:57 PM
Patches's Avatar
Patches
Here's how I jack my lowered vettes on the jacking bridge. There are a number of low profile scissor jacks and even hydraulic jacking bridges available to do this.
Old Jun 8, 2009 | 10:33 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
I have completed many upgrades on my 4 post lift...brakes, suspension, headers etc and never had any problems...
Old Jun 8, 2009 | 11:22 PM
spr95skt's Avatar
spr95skt
I have both, 2 post is much easier to perform all maintenance projects. 4 post is more suitable to me for storage. However, there are jack stands and other tools to facilitate the use of a 4 post if that is all you have. It all depende on your available space and ceiling height. Good luck
Old Jun 9, 2009 | 05:05 AM
9secondflat's Avatar
9secondflat
i had sex with my x on a 4 post...oh wait...different 4 post.
To What can be done on a 4-post?
