3.42 Gears Question
Feb 8, 2002 | 03:22 PM
3.42 Gears Question
Does anyone know if I can upgrade my stock 2.73's to 3.42's with any further mods required. If not, what else would be required to get the 3.42's?
Also, if you can recommend someone that can do this in the New York area that would be great.
Thanks in advance.
Feb 8, 2002 | 03:31 PM
Cruise-In II Veteran
Cruise-In III Veteran
Re: 3.42 Gears Question (C5Finally)
If you mean upgrading the 2.73 carrier you have with 3.42 ring and pinions. it wont work. the 2.73 carrier is a different animal.
Feb 8, 2002 | 04:12 PM
Re: 3.42 Gears Question (kewlbrz)
what kewlbrz said.
There is no upgrade in gear ratios for the 2.73 carrier . It was made to do 2.73 and nothing else.
Feb 8, 2002 | 10:09 PM
St. Jude Donor '07-'12, '20
You need to purchase a 3.42 rear..........
As well as computer update (programmer) for the new rear.
Money well spent trust me. :D :D :D :D :D
Vette doctors I believe is somewhere close to you.
Bob
Feb 9, 2002 | 09:41 AM
Re: 3.42 Gears Question (16Again)
FWIW,
Buy the 3.42's from GM and have them install them. You will pay slightly more, but there are a number of bad sets of 3.42's I've seen around, and if they are the GM gear, and installed by GM they and any installation are fully warrantied.
I had a set installed, they went bad, and GM warrantied the rear even though they were not stock.
Feb 9, 2002 | 09:50 AM
Check out the Vette Doctors in Amityville,N.Y. about 20 minutes from you!
They are Corvette Forum members AND a quality vendor:D
Feb 9, 2002 | 10:28 AM
Re: 3.42 Gears Question (vstella)
Is there anyone in SC that specializes in Corvette performance enhancements?
