Code B2265
Old Jun 9, 2009 | 06:18 PM
81c3's Avatar
81c3
Default Code B2265
This is in the Right Door Control Module section of the code list.
B2265 Horizontal Position Sensor Fault
Why would I get this? Is the sensor just bad? I swear I havent been pulling wheelies
Old Jun 9, 2009 | 11:23 PM
87SAM's Avatar
87SAM
DTC B2262-B2265
Circuit Description
The driver door module (DDM) and the passenger door module (PDM) receive mirror position signals from the mirror horizontal and vertical position sensors. These signals are used by the door modules for memory recall functions of the driver and passenger mirrors. The door modules command the mirror memory settings based upon the voltage level received back from the position sensors. Each door module provides a 5 volt supply, a signal and a ground circuit for each of the position sensors. The horizontal and vertical position sensors are variable resistors that the door modules monitor voltage levels across. When a memory setting is recalled, the door modules command the mirror motors in the appropriate directions until the stored position sensor voltage levels are achieved. The DDM and PDM monitor the signal circuits to determine if the voltage level is out of range. If the DDM or PDM detects a voltage level out of range for greater than 2 seconds, a DTC is set.
Conditions for Setting the DTC
The DDM or PDM detects a mirror position sensor signal voltage range under 0.1 volts or over 4.78 volts.
Condition must be present for greater than 2 seconds.
Action Taken When the DTC Sets
Stores a history DTC B2262, B2263, B2264 or B2265 in the DDM or PDM memory.
These DTCs can only be set as a history code even if the malfunction is current.
No driver warning message will be displayed for this DTC.
Conditions for Clearing the DTC
The DDM or PDM detects the correct mirror horizontal and vertical position sensor signal voltage range (0.1-4.78 volts) for longer than 2 seconds, and:
The DTC is cleared using the IPC clearing feature, or
The DTC is cleared using a scan tool.
Diagnostic Aids
An intermittent malfunction may be caused by an intermittent open or short to ground in a mirror signal circuit.
If the DTC does not reset after the code is cleared, then the problem may be intermittent. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This tests the mirror position sensor signal voltage using a scan tool. Normal signal voltage range is between 0.1-4.78 volts.
This tests the mirror position sensor signal voltage using a scan tool with the mirror disconnected. Normal signal voltage range with the mirror disconnected is greater than 4.78 volts.
This tests the mirror position sensor signal voltage using a scan tool with the signal circuit jumpered to the sensor ground circuit. Normal signal voltage range with the sensor jumpered to ground is less than 0.1 volt.
Step
Action
Value(s)
Yes
No
Schematic Reference: Door Control Module Schematics
Connector End View Reference: Power Door Systems Connector End Views
1
Did you perform the Door Systems Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Door Systems
2
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the appropriate mirror position parameter in the appropriate door control module data list.
Does the scan tool indicate that the mirror position parameter is within the specified range?
0.1-4.78 V
Go to Testing for Intermittent and Poor Connections in Wiring Systems
Go to Step 3
3
Turn OFF the ignition.
Disconnect the appropriate mirror.
Does the scan tool indicate that the mirror position parameter is greater than the specified value?
4.78 V
Go to Step 4
Go to Step 5
4
Connect a 3-amp fused jumper wire between the signal circuit of the appropriate mirror position sensor and the ground circuit of the appropriate mirror position sensor.
Does the scan tool indicate that the mirror position parameter is less than the specified value?
0.1 V
Go to Step 7
Go to Step 6
5
Test the appropriate mirror position signal circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 11
Go to Step 8
6
Test the appropriate mirror position signal circuit for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 11
Go to Step 8
7
Inspect for poor connections at the harness connector of the appropriate mirror. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 11
Go to Step 9
8
Inspect for poor connections at the harness connector of the appropriate door module. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 11
Go to Step 10
9
Replace the appropriate mirror. Refer to Mirror Replacement .
Did you complete the replacement?
Go to Step 11
10
Replace the appropriate door module. Refer to Door Control Module Replacement .
Go to Step 11
11
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Old Jun 10, 2009 | 12:10 AM
81c3's Avatar
81c3
Thank you very much!
To Code B2265
