Key Fob Problems...
Old Jun 12, 2009 | 03:53 AM
ragu1585's Avatar
ragu1585
Default Key Fob Problems...
ok so far ive tried, 2 transmitters, one that came with the car and one of a buddy of mine that needed a new batter, new batteries in both, i tried to "Match" the 2 key fobs to the car and ive tried Resynchronizing the fob also. Ive also checked fused 27, 33, and 34 and they were all good. car runs on a daily basis pretty much and battery is a yellow top optima and is good. i just bought the car a month ago and the previous owner said it worked for him, back when he first got it, if that matters. no tire pressure sensors present as ive seen some people refer to those.
so what do i try next??!!
Old Jun 12, 2009 | 08:06 AM
Blown 346's Avatar
Blown 346
Never heard if them not working with a good battery and re setting them.Works for me everytime.
How are you setting the transmitters?
Old Jun 12, 2009 | 09:02 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Two things. First is that you're using the correct year fobs. The 97-99 fobs have the on/off switch for the passive keyless entry system. The 2000 fobs transmit on the same frequency as the 97-99 but do not have the switch. The 01-04 fobs operate on a different frequency and will not work on a 97-00 car.
If you replaced the battery and the fob will not register with the car most likely the fob has died. Buy a new fob (Gene Culley at gmpartshouse.com seems to have the best prices) or do a search on here for the thread that details how to repair a dead fob.
Here's the link to the repair post:
http://forums.corvetteforum.com/c5-t...em-solved.html
Old Jun 12, 2009 | 09:42 AM
jimcork1's Avatar
jimcork1
I have had a total of 5 fobs in 75,000 miles on our 99 so IMO the fob is not very reliable.
Old Jun 12, 2009 | 10:07 AM
poolboy's Avatar
poolboy
What year is your car and what are the part numbers of your FOBs?
Old Jun 12, 2009 | 11:04 AM
BigGun's Avatar
BigGun
so what do i try next??!![/QUOTE]
Check and see if you have any communication issues with the RFA unit. This one U1176 Loss of Communications with RFA. B\G
Old Jun 12, 2009 | 11:59 AM
berryj's Avatar
berryj
You've probably already done this, but have you checked/replaced the battery inside the fobs themselves?
Old Jun 12, 2009 | 12:08 PM
ragu1585's Avatar
ragu1585
one of the fobs came with my 00 and the other was from my friends 99. so i assume they are the correct ones
Old Jun 12, 2009 | 12:13 PM
ragu1585's Avatar
ragu1585
Originally Posted by ragu1585
i tried to "Match" the 2 key fobs to the car and ive tried Resynchronizing the fob also..
ok so far ive tried new batteries in both.
Old Jun 12, 2009 | 12:14 PM
ragu1585's Avatar
ragu1585
Check and see if you have any communication issues with the RFA unit. This one U1176 Loss of Communications with RFA. B\G[/QUOTE]
thanks for that info ill try that asap
ill also try goin to the dealer to get them to test the fobs
Old Jun 12, 2009 | 01:56 PM
gpracer1's Avatar
gpracer1
Haha, before getting to the year , I was guessing its a 2000. Those fobs just plain die, and you will need a year 2000 specific fob. Trust me on this one.
Old Jun 12, 2009 | 02:52 PM
Mark C5's Avatar
Mark C5
Any fob from 97-00 will work. They all use the same frequency. 01-04 use a different frequency.
To Key Fob Problems...
