help for dual cone install
Old Jun 14, 2009 | 05:42 PM
jol's Avatar
jol
Default help for dual cone install
Can anyone show pics or write a brief install description for installing a dual cone system on a C5?
Thanks guys
Old Jun 14, 2009 | 05:59 PM
dancin1's Avatar
dancin1
Default Twin cone intake
Howdy, I installed one of these a month or so ago, I bought from that fleabay site and it came without any instructions at all. I did it with no problem, what kind of problem are you having installing it ?
Old Jun 14, 2009 | 06:01 PM
jol's Avatar
jol
We're at the point of cutting the shrowd since the cones are high so I wanted a pic of exactly where uou cut. I assume you just cut under the cones. Right?
Old Jun 14, 2009 | 06:05 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
It's pretty easy to do. Just take out the old and insert the new. Clamp everything down and you're good to go. No need to cut anything. I had one, but replaced it with a Vararam.
Old Jun 14, 2009 | 06:19 PM
jol's Avatar
jol
It's too high so the pins coming up from the stock housing doesn't reach the holes in the SLP system. Somewhere I read about cutting the shrowd so the cones sit lower.
I appreciate your help.
Old Jun 14, 2009 | 06:22 PM
JW Motorsports
Banned Scam/Spammer
Ok SLP huh? I don't know about that one. Maybe post a picture or two so we can see what the deal is.
Old Jun 14, 2009 | 06:23 PM
jol's Avatar
jol
It it ok to cut the shrowd?
Old Jun 14, 2009 | 06:26 PM
JW Motorsports
Banned Scam/Spammer
I don't see why not if you're willing to. Try to find instructions online or contact the manufacturer.
Old Jun 14, 2009 | 10:12 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
If you cut the shroud you will decrease airflow to your radiator and let in a lot more dirt to the engine compartment.
Old Jun 15, 2009 | 12:14 AM
jol's Avatar
jol
Thanks.
Old Jun 15, 2009 | 10:44 AM
dancin1's Avatar
dancin1
Default Twin cone intake...
I might be way off here, but, as I see it, if you have to cut anything, something else isn't quite right. I just did this a couple of monthes ago and nothing could have been easier. Just like JW said, you undo all the stock pieces, then put these back in their place. Mine was from that auction site and I ended up paying $30.00 bucks for mine shipped, brand new, so they could have been very badly manufactured and in fact I was expecting it, but, had no fitment problems at all. I can't imagine cutting the radiator shroud, I wouldn't for the reasons given above. Please make sure all is fitted properly and all pushed together, cause that's the only thing I can see that might be your problem.
To help for dual cone install
