Axle seal question...
Old Jun 15, 2009 | 11:27 AM
wcsinx's Avatar
wcsinx
Default Axle seal question...
It would appear my driver's side axle seal is seeping just a bit. From what I've gathered, this is pretty common. I'll swap it out this weekend, but I noticed there was a service bulletin issued for the axle seal as well as the driver's diff. cover seal. Is the concensus that both the axle and cover seal should be swapped at the same time? I.e. how common is it for both to be leaking? I can't really tell if the cover is leaking or not. There's a layer of grease on everything, but the only fluid oil I see is a wet streak at the base of where the half shaft plugs in.
Old Jun 15, 2009 | 12:18 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I ended up replacing the side cover O'ring and output shaft seal at the same time. The replacement cover O'ring is slightly larger diameter then the original in cross sections. Over 9K miles since change with no leaks.
Old Jun 15, 2009 | 12:48 PM
wcsinx's Avatar
wcsinx
Looking at this writeup ...
http://www.cajundude.com/outputshaftseal.htm
His method differs a bit from the factory. Would this method give me enough clearance to get the cover off, or should I plan on tearing it down farther?
Old Jun 15, 2009 | 01:07 PM
slothy's Avatar
slothy
to really find out spray down diff with brake cleaner and drive it a lil then go and check to see where the leak it.
Old Jun 15, 2009 | 01:24 PM
timemender's Avatar
timemender
If it’s seeping "just a bit" then you have time to clean off the differential then drive it awhile to locate any other leakage areas.
Be aware that the top vent is also known to expel lubricant, especially with an overfill condition.
If the side-cover is not leaking, I would leave it alone for now, but it’s your call. Replacing the side cover o-ring is not much more work to replace once the outer axles are out.
Old Jun 15, 2009 | 03:59 PM
wcsinx's Avatar
wcsinx
Knowing me and my overkilling ways I'll probably end up replacing the o-ring anyway. But just for kicks, I picked up a bottle of UV dye. I'm going to clean off the cover tonight, add the dye, and then reinspect it this weekend.
Old Jun 15, 2009 | 08:16 PM
donkelso's Avatar
donkelso
The procedure from cajun dude will give you enough clearance to get the side cover off. I used it when I did mine.
Old Jun 16, 2009 | 08:15 AM
wcsinx's Avatar
wcsinx
Good to know, thanks
To Axle seal question...
