Key FOB circuit board help
Old Jun 15, 2009 | 06:43 PM
Blackjetvette97's Avatar
Blackjetvette97
Default Key FOB circuit board help
Hi all,
Anyone out there live in Las Vegas/Henderson, NV area, who could help me with checking out a FOB board and the soldering connections since mine has issues. It will retrain and then quit working after that. I have tried the new batts, batt connections, etc. and nothing has worked. No idea if the connections are ok, as I can't see anything with my naked eye. I'd like to not "landfill" this thing and try to fix it before springing for a new one. By the way, my TPM's work, so that would indicate it's the FOB, correct? Thanks
Steve
Old Jun 15, 2009 | 07:51 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Steve, here's a link to a post that will tell you everything you need to know.
http://forums.corvetteforum.com/c5-t...em-solved.html
And yes it sounds like the fob is the problem.
