HVAC Compressor Clutch doesn't engage
Old Jun 15, 2009 | 09:51 PM
curtbriggs's Avatar
curtbriggs
Default HVAC Compressor Clutch doesn't engage
1999 with 53,000 miles. swaped the Micro Relay #34 and checked fuse #24. With the engine at idle, push the AC button and it flashes and goes out. Checked for codes with EFILive and none.
AC has been cooling fine but haven't checked system refrigerant yet.
A search showed every thing but clutch problems on the forum.
Anyone have to replace a clutch because of a like problem?
Thanks, Curt
Old Jun 15, 2009 | 11:13 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I had a very slow leak once that took about 3 weeks discharge to unacceptable levels. One day the a/c refused to get cold, I never heard the compressor kick on.
The tech told me it was because my refridgerant level was too low. He recharged the system (along with some dye) and it worked perfectly.
We found the leak eventually.
Old Jun 16, 2009 | 10:30 PM
curtbriggs's Avatar
curtbriggs
Default Compressor clutch
Thank you both for the replies.
Curt
Old Dec 9, 2009 | 01:48 PM
curtbriggs's Avatar
curtbriggs
[QUOTE=curtbriggs;1570462519]1999 with 53,000 miles. swaped the Micro Relay #34 and checked fuse #24. With the engine at idle, push the AC button and it flashes and goes out. Checked for codes with EFILive and none.
FIX: System low on refrigerant. After I charged it, works fine.
To HVAC Compressor Clutch doesn't engage
