Chemtool
Old Jun 16, 2009 | 06:24 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Chemtool
Has anyone ever used Chemtool gas treatment. I have a friend who swears by it. I believe that it will harm the fuel system and the injectors. Anything on this?
Old Jun 16, 2009 | 02:44 PM
TEXHAWK0's Avatar
TEXHAWK0
I have known mechanics to say that B12 Chemtool is the only really effective cleaner for fuel systems and you are wasting your time using anything else.
I have a can that is several years old, and it still states that it can be used to clean fuel injectors. Materials may have changed, but I would think it would still be alright.
However, I have used the full strength cleaner to clean carburetor parts and it was really strong, and would actually dissolve aluminum if you were too aggressive with it. You could soak parts with no problem, but if you brushed or agitated the parts, you could see some erosion.
http://www.bobistheoilguy.com/forums...Number=1069293
From Berryman FAQ website.....
Q. I have used B-12 Chemtool for years in my carburated vehicles and wonder if it will work as well in my fuel injected car?
A. Yes. The B-12 Chemtool was formulated to break down fuel deposits in the fuel tank. By ridding the fuel tank of gum and varnish, the passage of these impurities to the fuel injector and combustion chamber has been greatly reduced. It is these impurities that build up around the injector pintle that inhibit proper fuel flow and contribute to performance problems.
Old Jun 16, 2009 | 03:12 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
When it comes to fuel system cleaners, personally I would use only what GM recommends. Techron
To Chemtool
