Need some advice
Old Feb 9, 2002 | 05:32 PM
ROD BROWN's Avatar
ROD BROWN
Default Need some advice
I am planing to purchase the front and rear stabalizer kit from Ken Fitchner.Which stabalizer kit is better for an every day driver on the streets?The z51 or the Z06 are the same price,but Ineed some quidance which will perform better on my 99 Vette Coupe.Thanks to all who respond. :chevy :chevy :flag :chevy :chevy
Old Feb 9, 2002 | 05:36 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Need some advice (ROD BROWN)
:yesnod: I'm thinking Z06. :yesnod:
Old Feb 9, 2002 | 05:54 PM
luvinc5's Avatar
luvinc5
Default Re: Need some advice (Tx99FRC)
I have factory installed Z51 suspension on the vette and it's a very comfortable ride around town and holds tight around corners. I can't speak for the Z06 setup but if you drive your vette hard, get the Z06 setup.
Old Feb 9, 2002 | 05:57 PM
SONIC99's Avatar
SONIC99
I have the Z51 in my car and find that it handles well and still makes for a comfortable ride. I can't speak for the Z06 parts but I have not heard anyone complain about their ride comfort. I think you are just changing the bars and not the springs so the ride itself should not be too different IMO. If you are changing and the price is the same, I would probably just go for the Z06 kit.
Old Feb 9, 2002 | 07:10 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I went with the Z-51 and the metal links front and rear. The Z06 was not out at that time and the Z51 bars were a performance option in 00. I have the F-45 option and they work great. The bars are much heavier (thicker) than stock, I bet the two bars are similiar.
[Modified by wallstAL, 3:15 PM 2/9/2002]
Old Feb 9, 2002 | 07:35 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Another sway bar thread, go Z06 since the rear is the same as the Z-51, so they say!
http://forums.corvetteforum.com/zerothread?id=235328
Old Feb 9, 2002 | 09:03 PM
DraftMe's Avatar
DraftMe
Default Re: Need some advice (wallstAL)
Another vote for Z06! :cheers:
Old Feb 10, 2002 | 01:27 PM
movinup's Avatar
movinup
Default Re: Need some advice (J-C-5)
Ken just shipped my ZO6 sway bars so they should be here any
day now. He said the rear bars are the same as the Z51, but the
the ZO6 front bar is a little heavier.
Old Feb 10, 2002 | 01:49 PM
vette.se's Avatar
vette.se
To get the best handling go with T1-bars with heim-joint end links. The T1's are discussed right now in the following thread: http://forums.corvetteforum.com/zerothread?id=234786
You can find the T1's @ http://www.dougrippie.com
:cheers:
[Modified by seanr, 7:52 PM 2/10/2002]
To Need some advice
