Car getting hot when idling
Old Jun 17, 2009 | 01:31 PM
HarryO's Avatar
HarryO
Default Car getting hot when idling
I have a 2000 Convertible m-6. everything is OK unless the car is sitting for a while when in traffic. Then the temp starts climbing up to around 250 as soon as i start driving it goes back to normal. It has 20,000 miles. Any one have an idea where to start.
Old Jun 17, 2009 | 01:38 PM
dankhts's Avatar
dankhts
are your electric fans comming on? thermostat opening and closing? do you have a bunch of debri stuck on the front of the rad? garbage will collect in front of the rad..you could see it if you crawl underneath the front of the car and look up at the rad... .. is the rad core plugged with dirt/bugs? check the basic stuff 1st....and keep your fingers crossed that it's something simple and obvious...
Old Jun 17, 2009 | 02:19 PM
Blown 346's Avatar
Blown 346
I would do all the above, and check your coolant and see if its gummy. If it is I would flush the system.
Old Jun 17, 2009 | 02:31 PM
poolboy's Avatar
poolboy
I know it sounds counter intuitive, but when we run into heat problems while in parades we turn on the AC - it forces the fans on.
Old Jun 17, 2009 | 03:31 PM
HarryO's Avatar
HarryO
Thanks for the feedback, i will be checking it out this weekend
To Car getting hot when idling
