Astro Van 4L60E into corvette?
Old Jun 18, 2009 | 05:28 PM
fede_fly's Avatar
fede_fly
5th Gear
Default Astro Van 4L60E into corvette?
Hello people.
I have a 93 Chevy Astro Van with a 4.3 v6 engine and a 4L60E.
I would like to know if it will fit a C5 corvette.
Sorry if my question is stupid, but, I'm asking because the code is the same. The thing is they look different, the corvette's is shorter than the astro's, but The astro has three parts.
I need a hand here.
Thanks and congratulations for the forum.
Old Jun 18, 2009 | 05:36 PM
dougbfresh's Avatar
dougbfresh
No way Jose.
Old Jun 18, 2009 | 05:58 PM
fede_fly's Avatar
fede_fly
5th Gear
The problem with the tranny is:
It makes strange noises and it doesn't work normal.
It seems to confuse gears. sometimes when I put the D, from stop possition, It starts in 2nd gear, sometime when I'm in stop possition in D with the break pushed, the car seems to try to go forward and the engine stops (like bad clutch in a manual tranny)
I'm not an expert, but I think could be oil pressure problem???
Old Jun 18, 2009 | 06:49 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Don't know about the difference between the 2 or about the oil pressure. I can tell you that the Corvette 4L60E has different internals.
Old Jun 18, 2009 | 09:35 PM
WalterSobchak's Avatar
WalterSobchak
I wouldnt put anything from a 93 Astro Van in my corvette. That includes transporting parts of it in my hatch!
Old Jun 19, 2009 | 06:59 AM
fede_fly's Avatar
fede_fly
5th Gear
Thanks but you are not answering me.
Someone with a smart answer...?
fede_fly's Avatar
fede_fly
5th Gear
Thanks grandpas
Old Jun 19, 2009 | 07:06 AM
dougbfresh's Avatar
dougbfresh
Just look at the cases each trans is in-should tell you is 2 seconds.
Old Jun 19, 2009 | 10:45 AM
volk's Avatar
volk
You can't use the Astro's transmission in a Corvette.
What else do you need to know? Seems like they answered your question...
Old Jun 19, 2009 | 11:23 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
yes, cases are diff., 99% of us have never gone into a 4l60, we won't have the answer, but for now you'll get the cases are diff to fit the TT and diff
In the NE, i have a spare for 450, 2000 w/ 50k miles
Old Jun 19, 2009 | 11:28 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I believe that Mercury Mike put a torque converter from and Astro in his, but not to sure.
Check with him.
Old Jun 19, 2009 | 12:07 PM
Tkoscielniak's Avatar
Tkoscielniak
I have helped a buddy rework a 4L60e for his project Suburban and he used corvette parts to rebuild it including the servo. Point is, the transmission may work, but as stated earlier, there are instrnal "beefed up" parts in a Corvette transmission that make it able to handle the extra torque.
Old Jun 19, 2009 | 02:03 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
"dude, my trans is from an astro van!"
Old Jun 19, 2009 | 02:43 PM
Mike Mercury's Avatar
Mike Mercury
Check with him.
but that was just the torque converter... not the transmission itself.
Old Jun 19, 2009 | 03:19 PM
chaase's Avatar
chaase
St. Jude Donor '12
Internals are basically the same, but the casing is different because the corvette is a rear mount unit.
Old Jun 19, 2009 | 05:07 PM
fede_fly's Avatar
fede_fly
5th Gear
Thanks to all of you.
To Astro Van 4L60E into corvette?
