Roller Rockers
Old Jun 18, 2009 | 11:26 PM
Pace08's Avatar
Pace08
Default Roller Rockers
I am confused about the rocker arms on my 04 C-5. People refer to them as roller rockers. However, pictures seem to indicate that these are partial rollers. The only roller is the trunion part. I think my 1996 Grand Sport (LT-4) has full rollers produced by Crane. Am I correct about all of this? If this is correct, why would GM not use full rollers on the C-5. Does the C-6 have full rollers? Maybe it has to do with the redline on the Lt-4. Any ideas?
Old Jun 19, 2009 | 08:23 AM
slvr76's Avatar
slvr76
They are not true roller rockers. I'm not sure why the factory didn't use true rollers. You can install yella terras, harland sharp, etc... if you want true rollers. Some people have had an issue with the stock rockers spilling their needle bearings, especially after continued high rpm use. Others have done just fine with the stockers.
Old Jun 19, 2009 | 09:05 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Even the LS7 or LS9 has what you have (although the intake rocker tip is offset for geometry of valve placement) -The GM slider tips, only the fulcrum has roller bearings.
They are roller fulcrum.... But not full rollers. and another thing... it's been proven that valve lift over .550 requires full rollers shimed correctly for geometry. Bolting up stock rockers will lead to (issues) such as valve guide wear, burnt valve tips, and possibly broken springs over time. You can trash a nice set of heads with the wrong rockers.
Old Jun 19, 2009 | 11:55 AM
Pace08's Avatar
Pace08
Thanks for the info on the roller rockers. I guess the General did not want to spend money for full rollers, if it were not required to meet factory durability requirements. As best I can tell, the LT-4 engine must have been designed for a bit higher rpm.
Old Jun 19, 2009 | 01:18 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Default My thoughts...
GM was already in the final stages of approving the Gen III engine program.
With that being said, GM wanted to send the Gen II small block out with a bang (LT4) with the added extra rpm they needed a more robust rocker arm compared to the cheap 1.5 ratio stamped units used since '55.
Cheap stamped rocker:
Without investing money in R&D for a better rocker to handle the extra stress of the LT4's intended rpm... they decided to outsource (buy) full rollers from Crane since the Gen II engine program was on it's way out anyway. It was a limited production run.... and in my opinion, they made a great choice.
They did spend the money on better equipment for upcoming Gen III since it was a long term future powerplant. Not full rollers mind you... but better than before.
Old Jun 19, 2009 | 02:17 PM
Pace08's Avatar
Pace08
Thanks for the additional information and picture. I have seen the Rollers on my GS engine and they are really nice pieces of work. One can coax a lot of power out of the GS engine, but as with others, it costs.
Old Jun 19, 2009 | 08:47 PM
vettenuts's Avatar
vettenuts
Roller at the tip is only really needed for an aluminum rocker, as it doesn't roll it actually slides. It also adds weight at the tip, which is the worst place to add it.
Old Jun 19, 2009 | 09:14 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Slider tip rockers are limited by geometry. Running more than .550 lift on stock LS1/2/6 rockers means the user has no idea what he's doing to his valve guides, etc.
Running .600+ lift with stock rockers is flat out rediculous. Full roller rocker arms (full ark) have HUGE advantages over slider tip (partial ark) units. And it has nothing to do with aluminum.
Old Jun 19, 2009 | 09:43 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Please quit posting magazine article crap that was written by people that sell heads with bronze guides.
It was a glorified advertisement for Trickflow, with zero actual data backing it up, only theory and cute drawings.
Going on 4 years with .615" lift on stock rockers...no problem here!
BTW, aluminum rocker bodies are VERY susceptible to fatigue failure, that's one reason GM chose steel...
The other is they are very light over the valve, much moreso than any roller-tip rocker available today. No need for a crazy-heavy dual spring to support them in the fight against high RPM valve float.
The OE valvesprings and pushrods are the weak links the valvetrain. Upgrade both, and it will be stable to 7500+ RPM easily. Riocker arms included.
Old Jun 19, 2009 | 09:50 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Growing up around life long hot rodders, they've all used nothing but full rollers, and not because of Trick Flow heads.
Old Jun 19, 2009 | 09:53 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
So where are your proven facts that stock rockers are a detriment above .550" lift?
Honest question...Too many people have proven otherwise, I'm curious to see the other side of the claim.
Old Jun 19, 2009 | 10:09 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I can say from personal experience. I can't tell you how many cams I've helped swap in Gen III engines where the mood to go bigger strikes, but it's more than I can count on two hands.
In my own engine swapping to 918 springs with a new cam (.588 lift) the valve had almost no play within the guide. After 20k miles doing a routine spring swap checking the same play... A very fair amount of wiggle room.. in just 20k miles. So... it went from almost nothing on a virgin with 30k miles to "loose" with another 20k.
Not a single cammed car has had super tight spec (by feel) like a factory spec would.
I have nothing on paper, but I know.
To Roller Rockers
