Question re. Hypertech PP III
Old Feb 10, 2002 | 12:08 AM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
Default Question re. Hypertech PP III
I just bought a Hypertech Power Programmer III on Ebay. Got a great deal on it too. My question is this...
Do I need to install a lower temp thermostat in conjunction with the PPIII? Which one? Why? I live in the south so long warmup times is not an issue to me.
Thanks,
Dave :cheers:
Old Feb 10, 2002 | 03:36 AM
Drop_Top_Dave
Kid Rock Fan
Default Re: Question re. Hypertech PP III (Drop_Top_Dave)
Anyone? Buehler? :lol:
Old Feb 10, 2002 | 09:06 AM
BIG Dave's Avatar
BIG Dave
I had a HPP for my '95 LT1. When I ran the program into the Vette, it would ask me questions, one of which was if I installed a 160*F thermostat. If I answered "YES", then it installed a more aggressive program to get presumably more HP. Does the C5 HPP ask those questions like the C4 HPP?
Old Feb 10, 2002 | 09:23 AM
MAGRED 02's Avatar
MAGRED 02
When I had my 99 C5 A4 it was always running around 220 degrees. When I installed the HPPIII and the 160 Degree Thermostat my car never went over 190 degrees. I am going to add one to my 02 when a HPPIII comes out for my car. It is worth the $50 if you live in the South during the summer months.
Old Feb 10, 2002 | 12:58 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
That depends. :) If you want to try their tuning, you may need lower coolant temps to help guard against detonation. It does have fan control settings lower than stock for the OEM stat in addition to 180 and 160 stats.
Old Feb 11, 2002 | 12:52 AM
Drop_Top_Dave
Kid Rock Fan
OK, I ordered the 160* thermostat from COH to go with my PPIII. COH had the best price at $49.95! :cheers: Hope I get them both at the same time!!!
Old Feb 11, 2002 | 01:02 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I installed the HPP III in my car without the thermo. The car stays below 194 all the time. I also used a MAFT to fine tune the car and was able to dial in perfectly the Fuel, 02's, timing, KR, and so on... It was very happy with the results!!
vetterdstr :cheers:
Old Feb 11, 2002 | 08:15 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In III Veteran
Cruise-In VI Veteran
I have the same product and went with a 172 degree thermostat for a good all around range. Living in the south you shouldn't have any issues with the cold weather IMHO...
Nick
Old Feb 11, 2002 | 08:58 AM
JT-C6's Avatar
JT-C6
St. Jude Donor '03-'06-'08-'10-'11
Default Re: Question re. Hypertech PP III (Smoke-N-Shot)
You don't *need* to use the lower stat, but it helps. You can still change the shift firmness and use the hypertech tuning without the lowered stat.
To Question re. Hypertech PP III
