K & N filter for Vararam Industries VR-B2 C5 Corvette
In case anyone needs to know:
Vararam #KN332522B1B2 $69.95 Jan 2007
K&N # 33-2522
Product Specifications
Product Style: Panel Air Filter
Height: 0.688 in (17 mm)
Outside Length: 16.75 in (425 mm)
Outside Width: 5.313 in (135 mm)
Filter Re-Oiling Amount: 0.7 oz (21 ml)
Inner Wire: No
Top Style: Open
Weight: 0.9 lb (0.4 kg)
Product Box Length: 17.13 in (435 mm)
Product Box Width: 8.25 in (210 mm)
Product Box Height: 1.75 in (44 mm)
AC A1337C
TRIUMPH C29986
TRIUMPH C30489
WIX 46005
Fits
1975 - 1982 TRIUMPH TR-7 - 2000
Best E-bay $47.00
The K&N filter shown here is not a perfect fit. It's just rubber and it
doesn't seal real well inside the Vararam.
There have been many people fixing this problem with foam insulation of one type or another.
I am currently trying to fix this problem buy cutting apart the old
Vararam foam filter and re-gluing it to the K&N so there will be foam between the Vararam and the K&N, for better sealing.
I used a glue called E6000.
K&N # 33-2522
Inner Wire: No
Top Style: Open
AC A1337C
TRIUMPH C29986
TRIUMPH C30489
WIX 46005
Fits
Best E-bay $47.00
does the filter that comes with the vararam seal better than the k+n you posted. I know theres probably a filter war here somewhere on this forum but haven't searched yet.
