torque for intake bolts?
Old Jun 20, 2009 | 06:16 PM
5.0_CJ's Avatar
5.0_CJ
Default torque for intake bolts?
I've searched the tech forum for 10 minutes and couldn't find anything other than a pdf of torque specs which (hilariously) didn't have the intake manifold specs in foot lbs, and I only have my cheap torque wrench here that shows ft lbs only, not inch lbs.
Old Jun 20, 2009 | 06:23 PM
STL94LT1's Avatar
STL94LT1
First pass 5 N-m (44 lb in) 3.7 lb ft
Final pass 10 N-m (89 lb in) 7.4 lb ft
Old Jun 20, 2009 | 06:40 PM
LoneStarFRC's Avatar
LoneStarFRC
I would also recommend cleaning the threads of the bolts of any old residual thread locking compound and double checking that the bolt holes are clear/clean. Those bolts are very long and very thin and will twist or torque fairly easily. I like to use a drop or two of blue Loc-Tite too.
HTH
Old Jun 20, 2009 | 07:03 PM
SPS's Avatar
SPS
See at the bottom of the link, they show the proper sequence. No 8 and 9 are rather difficult to reach
http://pages.infinit.net/vette747/IntakeManifold
Old Jun 20, 2009 | 07:10 PM
Patches's Avatar
Patches
ft. lb. = in. lb. / 12 but you should really be using an inch-pound torque wrench since the torque level you'll be applying is at the low end of a foot-pound torque wrench where its accuracy is low. In fact, typical foot-pound torque wrench readings usually start at 10 ft. lb. so you probably can't even set it to the correct torque.
To torque for intake bolts?
