Turning MAF backwards to lean out mixture?
Old Feb 10, 2002 | 03:57 AM
Face's Avatar
Face
Default Turning MAF backwards to lean out mixture?
Since I removed the cats, my car has been running super rich. The other night I was told by a couple of other C5 owners that if I turned my MAF backwards, it help lean things out. Is there any truth to this?
Thanks,
Old Feb 10, 2002 | 04:06 AM
intel55's Avatar
intel55
Default Re: Turning MAF backwards to lean out mixture? (BLOWNGS)
no it richens it up.... tried it already... very slightly richens things up.. :cheers:
get a maft for a better solution.. or ls1edit
[Modified by intel55, 2:07 AM 2/10/2002]
Old Feb 10, 2002 | 10:03 AM
Mad_Dog's Avatar
Mad_Dog
Cruise-In II Veteran
Cruise-In III Veteran
You can use a MAF Translator to lean the mixture -- adjustments on WOT are from 2% to 14% lean in two % increments. Hope this helps. :D
Another point, if you have done nothing to trick the computer (O2 Sensors) you are most likely getting a false reading now, since you have no converters -- most buy a plug that hooks into the rear O2 sensors to send a false signal to the computer.
[Modified by Mad_Dog, 8:09 AM 2/10/2002]
Old Feb 10, 2002 | 02:24 PM
Face's Avatar
Face
Default Re: Turning MAF backwards to lean out mixture? (Mad_Dog)
I have O2 sims, so that's not a issue. As for buying a MAF T, I'm going to have some work done in the next month or so, and the car will be tuned then, I'm just looking for a quick fix for the time being.
Thanks,
Mike
To Turning MAF backwards to lean out mixture?
