Do clutch slave cyliners leak?
Old Jun 23, 2009 | 05:28 PM
hak's Avatar
hak
Default Do clutch slave cyliners leak?
I have a slow leak in my clutch fluid. I pulled the car apart to determine where it is coming from. The inside of the clutch access plate is wet with clutch fluid. The line attachment from the master to the slave appears to be dry. The bleed line appears to be dry. There is clutch fluid at the bottom of the slave cylinder where the spring is touching the slave cylinder housing. Has anyone had to replace their clutch slave cylinder because it leaks?
Thanks for your help.
Howard
Old Jun 23, 2009 | 06:03 PM
Bill Dearborn's Avatar
Bill Dearborn
Haven't had to do it on a C5 but have had to replace them due to leaks on other cars. There is no reason why a C5 slave wouldn't start to leak as well.
Bill
Old Jun 23, 2009 | 06:13 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I believe it falls under Murphy's Law - "Anything that can go wrong, will go wrong."
Old Jun 23, 2009 | 07:25 PM
LoneStarFRC's Avatar
LoneStarFRC
Yes.
Old Jun 23, 2009 | 11:25 PM
redrckt97's Avatar
redrckt97
mine sure did - got fliud all over the clutch -- first sign was chattering .. then pedal went half way down and stuck partially engaged .... had to replace the slave cylinder clutch etc ..big $$$
Old Jun 23, 2009 | 11:53 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Yes, they do leak. I would be happy to help you out with one.
89059282 - LS6 Slave Cylinder – 127.79
Old Jul 5, 2009 | 08:31 PM
Old Rotor Head's Avatar
Old Rotor Head
Yes and it stinks. Had a new C6Z for 15k miles, leaked and destroyed the disc, all the while changing the fluid every week pumping the HE!! out of it trying to keep clean fluid. Had the whole thing changed have 750 miles on it and guess what, I've had to change the fluid 5 times in 6weeks to be able to shift gears, not real happy at this point.
Old Jul 5, 2009 | 09:11 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
And in the worst possible location. Like the GD'ed slave.
The C4 slave could be easily replaced. The C5? Uh, no.
Old Jul 6, 2009 | 09:19 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
Yes they leak. Don't ask me how I know.
There is a very good thread on here about the slave cylinder that you should try to find. I think you'll find it very interesting.
Just found link.
http://forums.corvetteforum.com/c5-t...cs-inside.html
Old Jul 6, 2009 | 04:01 PM
KCvetteowner's Avatar
KCvetteowner
Good luck with your replacement. You might consider adding a heat shield to the clutch fluid line while you have it disconnected....
To Do clutch slave cyliners leak?
