Water Wetter?
Old Feb 11, 2002 | 11:48 PM
aces's Avatar
aces
Default Re: Water Wetter? (davidmax)
it's glorified water pump lube. :U
Old Feb 12, 2002 | 08:25 AM
Rx7Rob's Avatar
Rx7Rob
Default Re: Water Wetter? (aces)
Water Wetter is essentially a chemical known as Aerosol. Its also used in PhotoFlow when developing film. Even in very low concentrations, Aerosol will significantly decrease the surface tension of water.
I've never used it.
You won't see cooler temps, unless you're coolant typically runs hotter than the thermostat temp (otherwise the thermostat will close to maintain its temp).
BTW:.....I won't.......because the GM engineers didn't......... that kind of statement always has me ROFLMAO!!!!!!!
