Help!! ZF6 or a T56
I am looking to install one of these into a C1 corvette and wanted to know what the difference is between the two and if one happens to be better than the other.
Thanks for the help guys.
litetron@optonline.net
Banned Scam/Spammer
Try to get a t56 out a Camaro or Trans Am.
I will have a bellhousing and tailhousing unlike the Corvette's transaxle setup. It would make a better starting point.
If you're making enough power to justify it, T-56 Magnum is the way to go. Right out of the box, will tons more power than standard T-56. Bigger gears, shafts and bearings and made of better materials.
In the C5 and 6's, new Vipers, GT500's, it's called the T6060.
