Need help with Compression Ratio
Old Jun 24, 2009 | 12:31 PM
Fratbragen's Avatar
Fratbragen
Default Need help with Compression Ratio
Completely stock, expect for new AFR 205's with untouched 66 cc chambers. Not sure on what Gasket to use, but probably go with .04 thickness Cometic Gasket.
Thanks,
Matt
Old Jun 24, 2009 | 12:34 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You can use all the factory specs and change the gasket thickness with a compression ratio calculator to find your new compression.
http://www.rbracing-rsr.com/compstaticcalc.html
Old Jun 24, 2009 | 01:36 PM
Fratbragen's Avatar
Fratbragen
The calculator is helpful and not to sound like a dumbazz, but anyone know the basic stats on the stock motor?
Old Jun 24, 2009 | 02:04 PM
T_Vert's Avatar
T_Vert
You should check your DYNAMIC compression. Cam affects CR quite a bit.
Old Jun 24, 2009 | 02:18 PM
Fratbragen's Avatar
Fratbragen
Someone define the two different compressions. Thanks
Old Jun 24, 2009 | 02:26 PM
chevy406's Avatar
chevy406
A dynamic compression calculator factors in your valve opening and closing events, which is useful to know when selecting a camshaft.
For your stock LS1 with 66cc chambers, 3.9" bore, 3.622" stroke, 6.098" rod length, .006" piston out of hole, & zero dish or crown:
10.36 with a 0.056" MLS head gasket
10.76 with a 0.040" Cometic head gasket
The .040" would be a much better choice for you, with the small bump in compression and the tighter quench volume. If you let me know what engine and year you have (LS1 or LS6) I can also tell you the dynamic compression for a stock cam with those heads.
Old Jun 24, 2009 | 02:58 PM
Fratbragen's Avatar
Fratbragen
2003 coupe LS1 factory rated 350 hp, 375 tq. Hope that's what you need. Oh, 6 speed as well.
Old Jun 24, 2009 | 03:48 PM
chevy406's Avatar
chevy406
I have struck out trying to find the .006" lift duration numbers for a stock 03 LS1 cam. If I was to guess, you will have a DCR around 7.9 to low 8s with those heads and a stock cam. When you pick out a cam you should bump that DCR up around 8.5 by adding more duration.
Here is a screenshot of the Excel spreadsheet for my LS1, AFR, Comp Cam build to calculate DCR. You can download this spreadsheet by doing a search for PianoProdigy on LS1Tech.
Old Jun 24, 2009 | 03:54 PM
Tech's Avatar
Tech
You will definitely want to put a cam in the car when you install those AFRs.
To Need help with Compression Ratio
