Carbotech performance brakes
When you want the control and modulation to take your track-bred car deep into the turns, you need unsurpassed Carbotech brake technology. Going deep before you brake allows you to stay on the accelerator longer going into the corner and even faster coming out.
If you're a professional racer, or if you're taking your street car to the track for club events, Carbotech has the best braking solution. That's why we are becoming the #1 manufacturer of performance brake pads around the world with professional and club racers--everyone who demands the best. At Carbotech, we've been heavily involved in club and professional racing for more than 17 years. We know what you need to win.
Smarter construction.
Only Carbotech uses a proprietary Ceramic and Metallic brake construction, not the carbon and iron used in conventional brake systems. Since carbon and iron combine to form carbide, which is used in cutting tools, you can imagine what those brakes are doing to your rotors.
Carbotech Performance Brakes utilize true race compounds that are "rotor friendly," eliminating the grabbing and locking up that keep so many drivers and race cars from performing at their peak. You want to go deep to gain those precious fractions of a second before you need to brake, and only Carbotech brakes let you do just that. In every turn, all race long.
Custom solutions.
Designed by racers for racers, Carbotech brakes can be specified to meet the needs of your car and driving style. Just give us a call and we can recommend the compounds that will be perfect for your front and rear pads and shoes, assuring that they perform together with optimum effectiveness
Custom solutions.
Carbotech™ AX6™ (1106™)
The AX6™ takes the place of the Panther Plus™ compound that was so successful. AX6™ was specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range (150°F to 1250°F +). Advanced compound matrix provides an excellent initial “bite”, high coefficient of friction, and very progressive brake modulation and release characteristics. AX6™ offers high fade resistance, rotor friendliness at all temperatures, excellent cold stopping power, and non corrosive dust. As a result, AX6™ is an excellent choice for Autocross & novice track day drivers and beginner high performance driver education (HPDE) drivers on street driven cars using street tires eliminating the need to change brake pads at the track. AX6™ has gained tremendous popularity with SCCA Prosolo/Solo2 competitors for its fantastic bite, release & modulation. Many drivers use the AX6™ for street driving as well, even though Carbotech doesn’t recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT a race compound, and should not be used as such. AX6™ shouldn’t be used by any intermediate or advanced track day drivers, and should not be used with “R” compound tires (racing tires).
Carbotech XP8™ (1108™)
A high torque brake compound with a wide operating temperature range (200°F-1350°F+). Carbotech XP8™ is the first of our racing compounds. Outstanding initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance, very rotor friendly with 100% non-corrosive dust. Excellent as a front brake pad for lighter ITA, ITB, ITC, SRF, H4, H5, and other cars that weigh less than 2,400lbs. Perfect for novice, intermediate and advanced track day (HPDE) use with any tire, and can still be driven safely to and from the track. There are several vehicles that use XP8™ on the street, autocross, and at track day (HPDE) events. Carbotech does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. XP8™ is also a great rear brake pad for almost any race car (Spec Miata-T1/T2/CMC). XP8™ is a great compound on the front & rear of most open wheel and sports racers.
Carbotech™ XP10™ (1110™)
When Carbotech unleashed the XP10™ to the general public, and it was an instant success, gathering multiple regional, divisional, and national championships. The XP10™ is a very high initial bite friction material, with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1650°F. Due to the high level of friction and bite, this material is recommended for cars weighing around 2,000lbs or more, not including formula cars and cars with brake bias bars weighing less than 2,000lbs. This is the preferred compound for the front of Spec Miata racers, SSC,SSB, T3, SRF, ITS, ITE, H1,H2, H3, H4, 944 Cup, ST, GS, Factory Five Cobra’s and many more Grand-Am/ALMS/SCCA/NASA classes. XP10™ is also ideal for advanced/instructor level HPDE drivers. XP10™ still maintains the highly praised release and excellent modulation, rotor friendliness, and 100% non-corrosive dust that have made all Carbotech compounds so successful. XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
F: CT731 AX6 XP8 XP10
$159 $181 $199
R: CT732 AX6 XP8 XP10
$135 $153 $172
Go Deeper Into the Corners on Lapping Days!
When you take your car to the track, you want to know you can charge aggressively into the corners and be sure your brakes will shear off that speed—giving you maximum control without unnecessarily sacrificing pace. Just call us and our racing specialists will help you determine the perfect brake pad compound for your car and your style of driving. Carbotech brakes are designed to allow you to “Go Deep!” while being particularly friendly to your rotors.
