I think I got big TROUBLE
Old Jun 29, 2009 | 10:20 PM
99torchredlb's Avatar
99torchredlb
Originally Posted by lucky131969
I would like to know more about these diamond coated bolts as well....
Me to
Old Jun 30, 2009 | 08:33 AM
Blown427conv's Avatar
Blown427conv
I can't find the thread now, but they were called a "band aid fix" by one of our very knowledgeable sounding members. The idea is that they are installed after the balancer is pressed on tight and they dig slightly into the metal on the balancer to keep the bolt from backing out and the balancer from spinning. I think they use a type of locktite on the threads also. I looked for 2 hours for the thread, but it started off as just an overheating or power steering problem or something along those lines when several very sharp members led him to check the balancer. It was part of a GM fix probably a Service bulletin where the crank was inspected, the balancer was replaced and installed by the old bolt, and this special one installed. I've also read someone else refer to this "fix" as a grit coated washer, but one of the members discussing the bolt was using part numbers while I believe another confirmed it. We need a GM parts guy to help us out on this one...
Old Jun 30, 2009 | 04:10 PM
lucky131969's Avatar
lucky131969
There is a fix...pinning the assembly, or a keyed crank.
To the OP, don't get distracted by proposed "band aid" fixes. Buy a quality balancer, use the proper tools to install, pin the assembly, and torque per the service manual.
Old Jun 30, 2009 | 08:35 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
None of what you describe is an approved method for threaded fastener locking. I have an ALLDATA account and I've never seen that TSB (technical service bulletin) come through, do you know the TSB number?
