Find the squeaky sound in a c5?!?
Old Jun 27, 2009 | 05:24 PM
Earnhardtsvette's Avatar
Earnhardtsvette
2nd Gear
Default Find the squeaky sound in a c5?!?
I have a annoying squeak coming from the driver rear. It is high pitch and occasionaly will stop for a day or two and then return. It is very sensetive so much so that i can cancel out bushings and bearings! Because you can move the car with 1 finger 1/16th of a mm and it will squeak!
Any ideas? or has anyone come across this with there vette?
Old Jun 27, 2009 | 06:04 PM
ericdwong's Avatar
ericdwong
Does it get louder if you're turning one way (in your case, probably turning right), especially on sweeping turns? Does it go away when you drive in the rain (if you drive in the rain)?
Old Jun 27, 2009 | 09:07 PM
Earnhardtsvette
2nd Gear
No it litterally happens regaurdless of what i do! I can tap the back of the car with my hand gentlly and it happens.... I did recently have my drivers side rear axle replaced by GM but thats about it! I looked at all the bushings and the shocks but i cant figure it out?!? I bought it about a month ago and broke the axle because i was an idiot and did a nuetral drop with traction control on but aside from my idiocy i'm stumped?
Old Jun 27, 2009 | 10:42 PM
mcgilles's Avatar
mcgilles
mine does that also, although its not as sensitive as yours, it takes more suspension travel to make mine do it. let me know if you ever figure it out! I haven't had any luck finding mine yet.
Old Jun 27, 2009 | 11:08 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
It might be worth having a friend push on the car to make the noise and then you go around the car and find where it is the loudest. I would think you could at least get it narrowed down to what part is making the noise. Keep us posted on what you find.
Old Jun 28, 2009 | 11:29 AM
ericdwong's Avatar
ericdwong
One thing to check- the top of the shock mounts. My car made a really strange noise while driving, it was squeakin all over the place. But would quiet down when driven in the rain, so I knew it was something on the outside of the car. Turns out there was some corrosion or dirt at the upper shock mount. I cleaned it off thoroughly and the squeek was gone.
Old Jun 28, 2009 | 03:47 PM
jedblanks's Avatar
jedblanks
Sway bar bushings. It's always the sway bar bushings.
To Find the squeaky sound in a c5?!?
