squeaky belt?????
Old Jun 28, 2009 | 01:05 PM
bmfrc's Avatar
bmfrc
Default squeaky belt?????
anyone else had problems with the main belt making noise on their c5s? I know its the belt, I can spray a little silicone spray and it stops for a short while. I replaced the belt and was good for a while, but then it came back. I turned the belt the other way, now I hear it around 1500 rpm on the road. could something be wrong with a pulley? such an annoying sound....
Old Jun 28, 2009 | 07:06 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
First check the harmonic balancer and see if its wobbling. If so, you need to take care of that in the very near future if not now. Secondly, you can replace the belt with something like a GatorBack.
Old Jun 28, 2009 | 10:09 PM
JCamaro's Avatar
JCamaro
Search will help you find dozens of belt chirp threads with info on how to diagnose a bad belt versus a harmonic balancer issue.
Old Jun 28, 2009 | 11:35 PM
YellowFlash's Avatar
YellowFlash
CI 7 & 9 Veteran
Default Maybe it's the water pump
I recently had a chirping /squealing sound and thought it was the belts too. I only heard the noise when I first started her up cold; but it went away after it warmed up. The noise became increasingly noisier and lasted longer as the weeks went by. I then started losing coolant and suspected the water pump . It ended up being a leaky water pump; which I replaced and now I have no noise.
Are you losing any coolant?
Old Jun 30, 2009 | 09:19 AM
bmfrc's Avatar
bmfrc
not losing any coolant, however, I did look at the balancer with the car running, and it looks like it is running a little off center. Is the front pulley part of the balancer, or just bolted to it. looks like a pain to pull the balancer!!!!
Old Jun 30, 2009 | 09:32 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Yes, it is a pain to replace, yes, it is a part of the balancer, no, it is not bolted to it, it has an elastomer bonding the pulley and the crankshaft hub together. This elastomer will sometimes break down allowing the two pieces to seperate. Not good!
Old Jun 30, 2009 | 09:34 AM
Blown427conv's Avatar
Blown427conv
check out the threads for a slipping pulley on here to hopefully rule that problem out. The pulley and balancer are one unit and very unpleasant to replace. The wobble can cause the squeeking. If the balancer is found to be on tight, another old trick is to hold a bar of soap on the contact sides of the belt while it is running as safely as possible to quiet it down. I wouldn't use silicone spray, it will coat the belt and make it slicker. Also as mentioned above, a pulley or pump could be dying. I'd pop the belt off and spin each one by hand fast and slow to see if any have a grinding or feel tight. Also try wiggling the pulleys, there should be little to no play with the belt off.
Old Jun 30, 2009 | 10:21 AM
ecoman's Avatar
ecoman
Old Jun 30, 2009 | 12:12 PM
Vetterthanyou2's Avatar
Vetterthanyou2
I had the same prob. Especially when cold.
I changed the tensioner pulley and it rarely does it anymore.
Old Jul 2, 2009 | 08:24 AM
bmfrc's Avatar
bmfrc
I think im gonna try the soap, havent heard that one yet. the noise is definetly worse in cold weather, but its summer time here in texas, so i can turn the radio up a little and not hear it any more!!! I re greased the bearings in the tensioner and idler a while back, made no diff. even tried pulling more tension on the tensioner pulley with the car running, still no difference... I will let you guys know what happens with soap on the belt.
Old Jul 2, 2009 | 01:58 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
about 600 bux to have it done.
IT could also be one of the 2 pullies for the ac belt
Or caused from the balancer seperating also causing failure on the tensioner pulley.
Old Jul 2, 2009 | 07:54 PM
steveovette's Avatar
steveovette
The noise is caused by coolant leaking from the water pump. Check really closely and you will see staining from the weep hole on the pump. The clue is the noise only happens when it's cold. Replace the pump and belt and your problem is solved.
To squeaky belt?????
