need help!
Old Jun 28, 2009 | 01:05 PM
black 99's Avatar
black 99
Default need help!
Will 12mm torque tube bushing fit in my m6 99 vert. i am going to buy a set i just want to make sure they will fit before i shell out over a hundred dollars. Any help will be appreciated. Thanks Jason
Old Jun 29, 2009 | 07:32 AM
clif's Avatar
clif
St. Jude Donor '09-'10
If your car is an A4, then by dfault the answer is NO, the 12MM propeller shaft will not fit. For my car, I got a new custom propeller shaft with 12MM bolt holes in the end. I also got a solid bushing for the rear for 12MM, and a rubber one up front. My input and output shafts had to be drilled out and tapped to 12MM as well. Overall, mine is a lot stronger, but it was not a cheap upgrade.
Old Jun 29, 2009 | 10:30 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You can buy a later 2001 - up automatic torque tube that will be stronger than the pre 2001 models but they still have 10mm bolt holes.
The 2001 and later torque tubes have a thicker aluminum inner drive shaft.
To need help!
