c1214
Old Jun 30, 2009 | 10:39 PM
cobra3's Avatar
cobra3
Default c1214
well I have a code c1214 stored , I cleaned the grounds under the hood and under the dash. Took the ground connection apart and cleaned all the terminals . I also just replaced the battery , old one tested bad so I put in a optima red top. I unpluged the switch on the abs modulator and checked the wires and the plug but did not see anything wrong with either. I guess I need a new direction to go in if anyone can point me in the right direction it would be great.
thanks in advance
Richard
Old Jul 1, 2009 | 06:58 AM
dougbfresh's Avatar
dougbfresh
www.absfixer.com and $150-200 bucks will fix your problem.
