Help Please-Code C1225 RF Excessive Wheel Speed Variation
Old Feb 11, 2002 | 04:33 PM
gbecton's Avatar
gbecton
Default Help Please-Code C1225 RF Excessive Wheel Speed Variation
I have had the hub and sensor replaced three (3) times as a result of the code C1225. The problem keeps coming back. Any suggestions. Thanks.
Old Feb 11, 2002 | 04:35 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Help Please-Code C1225 RF Excessive Wheel Speed Variation (gbecton)
Do you have stock wheels on the car?
Old Feb 11, 2002 | 05:15 PM
gbecton's Avatar
gbecton
Default Re: Help Please-Code C1225 RF Excessive Wheel Speed Variation (MattG)
Yes, stock wheels. Thanks for your response.
[Modified by gbecton, 3:16 PM 2/11/2002]
Old Feb 11, 2002 | 07:39 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The most common fault is related to the "jumper harness" that goes to the sensor...You can substitute the left and right harness to see if the fault moves (C1226 code),but I would just replace them...Suspension travel causes open circuits in the jumper harness...
Old Feb 11, 2002 | 07:48 PM
gbecton's Avatar
gbecton
Default Re: (C-5 TECH)
Thanks for the insight, I'll inform the service manager when I take the vehicle back to the dealership tommorro.
Old Feb 11, 2002 | 08:22 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: (gbecton)
do you have SS brake lines on your car?
vetterdstr :cheers:
Old Feb 11, 2002 | 09:27 PM
gbecton's Avatar
gbecton
Default Re: (vetterdstr)
Yes it does have the SS brake lines. Sorry I missed your run this past Saturday, I hear it was great.
[Modified by gbecton, 10:45 PM 2/11/2002]
Old Feb 12, 2002 | 01:44 AM
vetterdstr's Avatar
vetterdstr
Sorry we missed you too at the Event!! :eek: what type of SS lines do you have?
vetterdstr :cheers:
Old Feb 12, 2002 | 11:15 AM
gbecton's Avatar
gbecton
No clue, I'll ask Terry Fong, he put them on. Thanks for your input.
Old Feb 12, 2002 | 11:30 AM
vetterdstr's Avatar
vetterdstr
Did the problem start after the install of the SS lines??? If you have the Russell's (spelling) that is the problem... those are not grounded correctly. thus the codes..... get the Goodridge SS brake lines I went through the same thing on my car. The dealership spent lots of time figuring it out for me... at no cost even!! :)
vetterdstr
Old Feb 12, 2002 | 11:38 AM
gbecton's Avatar
gbecton
The problem started on the way from Palm Desert to Las Vegas on the roads with many dips in the road, in fact I think I was close to being airborne on some of the dips. This was several months and many miles after installing the SS brake line. Thanks for your input.
Old Feb 12, 2002 | 11:44 AM
vetterdstr's Avatar
vetterdstr
FYI, my russell SSBL's would throw a code when I hit a slight bump in the road. And other times would just short out at low speed indicating a 9 mph variation for a split second. That variation would throw the code to the EBTCM.
My car had the wheel sensors replaced, EBTCM replaced, and it turned out to be the Russell SSBL's... whatever is happening with your car, I hope you get it fixed! :)
vetterdstr :cheers:
Old Feb 12, 2002 | 03:03 PM
gbecton's Avatar
gbecton
Thanks, it's at the service department as I type. I talked to T. Fong, they (SS Lines) are the Russell Type. I'll let you know what happens. Thanks again.
To Help Please-Code C1225 RF Excessive Wheel Speed Variation
