installing a gear
what all needs to be done to successfully install a gear..
will i have to do a recalibration for the speedo and odometer..??
any tips and advice would be great!!
For the gear set install, I don't recommend it as a DIY job. Unless you have a hydraulic press, pinion depth setter, and a lot of experience using them. I have no problems R&R-ing my engine, trans, clutch replacement, etc....but I don't touch rear diff gears.
Last edited by crainholio; Jul 2, 2009 at 04:40 PM. Reason: Correction thanks to Mike Mercury
My guess is the info is out there somewhere, but it wouldn't surprise to find it all in German. Spreken ze Deutsch?
if you want to actually change just the actual gears in the differential--don't. these rear ends are a PAIN IN THE @$$ to set up correctly.
i'd strongly recommend you buy a rear end with the gears you want in it already and just sell the stock one. it will cost a bit more up front but it also turns the job into something you might could do on your own.
it isn't too hard to change the whole differential. basically you'll be dropping the rear cradle (which is like 4 nuts) and just unbolting the diff/unhooking any wiring. install new one in the reverse order and fill with correct fluid (usually GM syncromesh..or at least it used to be).
there are surely some write-ups around here somewhere but IMO that's the way to go.
(oh, and this car isn't from Germany
..so the instructions should be in English)
for the new gear, in order for the speedo and odometer to be accurate.
there is no speedo/odo error induced when changing the rear axle ratio on any C5... PERIOD !
There's reasons to reprog for a rear axle ratio change on an automatic C5 (though it has nothing to do with the speedo or odometer). Manual shift C5's require no reprog at all. The OP has a Z06.
No need to guess at answers here; there's plenty of people here on CF that know the accurate details.
for the OP; here's some installation info:
http://mikemercury.home.att.net/342.htm
I agree with the others; replace the entire unit (carrier) . Leave the internal ring & pinion swap to the professionals. The Getrag differential is too unique.
On the LS1s I've worked on, the PCM only reads reluctor pulses from the Vehicle Speed Sensor which tell it how many rotations the output shaft has turned. The PCM then calculates a miles/hour speed based on two configured variables:
1.) Tire diameter.
2.) Final gear ratio.
If you alter either of those two, the PCM will incorrectly report vehicle speed. Are C5 manual-trans PCMs configured differently, such that they use a different input for vehicle speed?
I can imagine the ABS reluctors would provide reasonably-accurate vehicle speed input independent of gear ratio...but they'd still be thrown off by changing tire diameter.
1.) Tire diameter.
On automatics though of course it needs a little more information to correctly calculate what's going on in the tranny. Comparing axle speeds, RPM and what gear the tranny is in is useless if it doesn't know the rear end ratios. But, for M6's it doesn't matter since the computer doesn't do anything in regards to shifting.
this is such old news that the only people that get it wrong are those that try to "reason" to get the answer.
I believe the problem is that you are indeed relying on others
to give you the info. Instead; this time find it out yourself. All you need do is see where the VSS is physically located on the C5. Then you don't hafta rely on others to give you the accurate info.
Those cars acquire VSS data from the output shaft of the transmission itself, using a magnetic sensor installed in the T56 and 4L60E trans tailshaft housing. Installing a different rear gear ratio will very much throw off the PCM calculation of vehicle speed in those systems.
I recognize that the Y-body is a different animal. I left room in my statements for some difference in Y-body data acquisition, and hoped you might clarify.
The Corvette is indeed different than other users of the LS1. Sometimes we're proud of that... other times we curse it
