brake/clutch fluid
Old Jul 3, 2009 | 12:11 AM
MIBagentR's Avatar
MIBagentR
Default brake/clutch fluid
Just a NOOB question:
Does the brake and clutch fluid use the same reservoir? If so if I bleed my brake lines do I have to bleed my clutch lines? Will bleeding my brake lines clean my clutch line?
Old Jul 3, 2009 | 12:45 AM
KCvetteowner's Avatar
KCvetteowner
Different reservoirs....smaller one close to the wiper fluid tank is clutch, next to it and closer to the motor is the brake reservoir.
Old Jul 3, 2009 | 12:48 AM
rws.1's Avatar
rws.1
different reservoirs but use the same spec fluid.
Old Jul 4, 2009 | 10:05 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
i use DOT 3 and change both every 6 months. its simple and easy
To brake/clutch fluid
