Reseting TPS on 01
Old Jul 4, 2009 | 01:26 PM
3whit's Avatar
3whit
Default Reseting TPS on 01
Need help ,I replaced these when I put new tires on . They were used but supposedly functional. I can't get the drivers front to beep so consequently I cant get it done. If I continue around the car the passenger side front wont beep , if I continue to the passenger rear it beeps easily, The drivers rear beeps easily also . So I know they are not programing since the first one doesn't beep. Can I make the assumption that because the rears beep that the batteries are good in those sensors???????, I have done this before on my 99 so I have the procedure, I am using a speaker magnet which is plenty powerful.Help ,suggestions ,solutions,?????? Thanks Just would like to have it work since it is available ..Thanks in advance for your help
Old Jul 4, 2009 | 03:36 PM
TheBriton's Avatar
TheBriton
Hey Whit,
Sounds to me like you've got two bad sensors. Prolly need batteries.
Jim
Old Jul 4, 2009 | 03:49 PM
timemender's Avatar
timemender
The ones that cause a beep most likely are working OK.
A large speaker magnet works fine as proven on the working sensors that cause a beep.
P.S. - There is a forum member that rebuilds the earlier models (97-2000). Forgot his name - do a search.
The 2001 - 2004 are cheaper and best to replace with new since there is no price advantage.
P.P.S. - I see you have a 2001
Old Jul 4, 2009 | 03:50 PM
kh400's Avatar
kh400
Originally Posted by TheBriton
Hey Whit,
Jim
Can you just replace the battery or do you have to buy a new sensor?
Old Jul 4, 2009 | 04:17 PM
3whit's Avatar
3whit
Ya I'm thinking that your right Mr. Briton . New sensors arn't that bad cost wise just having to dismount tires etc . Maybe I will just live without it till I change out the run flats.Thanks for your reply .
To Reseting TPS on 01
