Engine swap question
Old Jul 7, 2009 | 01:45 AM
Lvnspeed's Avatar
Lvnspeed
Default Engine swap question
I have a friend who gernaded a motor on spray....... The question is he found a motor complete with wiring harness and ECU locally but it has a lot less miles on it than his motor. If we install it complete as is will it show the lower miles on the guage in the car?
Old Jul 7, 2009 | 01:51 AM
c5runs's Avatar
c5runs
the mileage will read whatever it was before. installing a new or used engine will not reset the current mileage in any way.
Old Jul 7, 2009 | 01:56 AM
Lvnspeed's Avatar
Lvnspeed
is the mileage stored in the Motor ECU?
Old Jul 7, 2009 | 07:19 AM
rebelheart's Avatar
rebelheart
It may well be stored in the ECU but I am not sure either.But why change it? Swap the components that may be different from the bad engine to the new one and leave the ECU alone.
Old Jul 7, 2009 | 02:24 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
I would do a little leg work before messing with the odometer reading. Might end up breaking some laws on tampering.
Old Jul 8, 2009 | 04:15 AM
Lvnspeed's Avatar
Lvnspeed
we are not looking to mess with the odometer just coruious.
Old Jul 8, 2009 | 12:36 PM
MattB's Avatar
MattB
No, the odometer is stored in the DIC.
Post up what type of engine and the year/model it came out of and someone here may be able to give specific advice.
In general, you want to keep your stock PCM (ECU) as it works with the BCM for security. If the new engine has modifications to its tune, a tuner can read the tune off of it and just update your PCM with the needed changes.
Old Jul 8, 2009 | 12:50 PM
LoneStarFRC's Avatar
LoneStarFRC
The DIC has the mileage, not the PCM. Also need to state what kind of car it's going in too. The OP doesn't even state what kind of car his friend has. Might be an F-Body or even a street rod for all we know.
To Engine swap question
