C6 wheels on C5
Old Jul 8, 2009 | 01:34 PM
NealB's Avatar
NealB
Default C6 wheels on C5
I know this must have been posted a zillion times, but don't spot anything with a search
what does it take to fit C6 wheels (non-Z06) onto a C5 ?
spacers? hub adapter?
Old Jul 8, 2009 | 03:03 PM
jaymsu's Avatar
jaymsu
I was looking for an answer for the same question. Any one out there to help us, please??
Old Jul 8, 2009 | 03:30 PM
97C5owner's Avatar
97C5owner
Do a forum search. One of the vendors here makes the adapter specifically for this purpose. Its appx 1 in and makes the wheel set flush with the fender. Good looking setup.
Old Jul 9, 2009 | 12:29 AM
chevylad's Avatar
chevylad
what are you trying to accomplish, the look of the wheel or the bigger sizes of the C6?
Only reason I ask is because the C6 rims come in C5 sizes through the aftermarket. Reuse the tpm and tires and you get the look.
BTW, if you are looking for performance, run the smallest size rim that fits over your brakes. Bigger diameter wheels take some distance out of your braking.
Old Jul 9, 2009 | 12:47 AM
Ayankees2772's Avatar
Ayankees2772
I have c6 wheels on my c5. I purchased wheel spacers but did not need them. I have the c6 five spoke style w 285 in the rear.
Old Jul 9, 2009 | 09:17 AM
NealB's Avatar
NealB
to change the look and to be able to use new generation run flats
we take 3000-4000 mile trips in the Zee each summer, and would like runflats for that use
thought I understood that the fronts would bolt on directly but the rears need a fairly thick spacer (and longer studs)
Old Jul 9, 2009 | 11:08 AM
hector88's Avatar
hector88
i installed some c6 wheels in my z while my new wheels got here. they stick in a little but can be use like that. if u want them to fit flush u r going to need a spacer fot the rear.
Old Jul 9, 2009 | 02:22 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
I just picked up a 2000 hardtop a couple weeks ago. Still had the original tires on it. Since I had done the widebody on my 08 I had my stock 08 gumby wheels and tires sitting around. I put them on the car and they fit fine. As someone mentioned, the rears sit inboard a little more than the C5 wheels did. I'd love to know who this vendor is that is making spacers for this setup. Also, the C6 pressure sensors obviously don't work with the C5 computer so I'm trying to find information on whether the C5 sensors will fit on the C6 wheels. So far I have not found a definitive answer to this. Anyone have solid info on this?
Old Jul 9, 2009 | 02:24 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
What did you do about the tire pressure sensors? Were you able to put the C5 sensors on the C6 wheels?
Old Jul 9, 2009 | 04:29 PM
my6thvette's Avatar
my6thvette
The C6 wheels will fit on most C5s. The rear wheels will set rather close to the rear fender wells, and in some cases, may rub. If this should occur, a 1/4 inch spacer should solve the problem. The C6 wheels fit my 1999 C5, with no spacers, and did not rub.
Yes, the C5 sensors will fit on the C6 wheels.
This is how the OEM C6 wheels fit in the rear wheel wells, as compared to the C5 wheels.
C6 wheels
C5 wheels The appearance is really not that much different.
Old Jul 9, 2009 | 04:37 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
Thanks for the info on the sensors.
To C6 wheels on C5
