rdcm-no comm.01 corvette
Old Jul 8, 2009 | 04:30 PM
jthomp2's Avatar
jthomp2
1st Gear
Default rdcm-no comm.01 corvette
the rt. window nor the rt. pwr. mirror operate after going through the codes the message was "rdcm-no comm."is it the control mod. or just a ground?
Old Jul 8, 2009 | 06:52 PM
timemender's Avatar
timemender
Here’s a starting point, see if it helps -
Check the connectors in the door hinge area (in the rubber accordion). The rubber accordion easily dislodges. Loosen it and take the connectors apart and PROPERLY inspect that each terminal within the connector is tight and free of corrosion.
Look for any exposed wires at the terminals. I don’t think that is your specific problem at this time, but if you find any you should coat the bare wire(s) with liquid electrical tape and maybe regular electrical tape over that.
It is always good to check the related grounds with ANY electrical trouble. (Finding all the grounds & "ground packs", coating the inside with anti-corrosive compond is ALWAYS a good idea to head off future troubles)
These links may help -
Door Lock & Window Problems
http://forums.corvetteforum.com/c5-t...ndow-inop.html
Electrical Info Thread:
http://forums.corvetteforum.com/c5-t...tion-long.html
Post #316 (page 16)
http://forums.corvetteforum.com/c5-t...n-long-16.html
Post #640 (page32)
http://forums.corvetteforum.com/c5-t...n-long-32.html
Old Jul 8, 2009 | 07:01 PM
JAY KOCH's Avatar
JAY KOCH
This is from page 18 of the "Important Elec. Info." Sticky.
http://forums.corvetteforum.com/c5-t...n-long-18.html
Check out this page and subsequent pages.
Good luck.
To rdcm-no comm.01 corvette
