Run rear 18" on the front?
Old Jul 9, 2009 | 11:24 PM
MJD's Avatar
MJD
Default Run rear 18" on the front?
Thinking of running rear 18" thinspokes on the front and having another set of rears widened for the rear. Looking to do something custom without having to drop a lot of coin. Any one run rears on the front? Need to find out if they will work.
Old Jul 9, 2009 | 11:38 PM
Its_Go_Time's Avatar
Its_Go_Time
I do, with 285/35-18's.
Old Jul 9, 2009 | 11:44 PM
MJD's Avatar
MJD
Any issues? How's the fit? Thanks.
Old Jul 10, 2009 | 02:15 AM
Thickraybans's Avatar
Thickraybans
Stock 18" front 18x10.5 Toplines in back tires in sig.
Old Jul 10, 2009 | 09:25 AM
Blown427conv's Avatar
Blown427conv
I have 265/35/18's on front and 295/35/18's on the rear. The rears may be 40 series, can't remember for sure. My wheels are the ZO6 knock offs of an unknown brand. No TC or rubbing issues and the car is lowered 1"+
Old Jul 10, 2009 | 02:42 PM
topless99's Avatar
topless99
I run 4 rear wagon wheels on my 99 vert. 275's on the front and 295's on the rear. lowered all the way on stock bolts. aside from bottoming out a lot on the horrible roads around here no problems.
Old Jul 10, 2009 | 02:50 PM
BUGZ's Avatar
BUGZ
I run 275/35?/18 in the front, 295/30?/18 rear...no issues.
Old Jul 10, 2009 | 04:14 PM
tommie's Avatar
tommie
what about a wider 18" rear thinspoke?
Topline?
who sells them?
Old Jul 10, 2009 | 05:45 PM
Its_Go_Time
They fit well. The car is lowered quite a bit, so the outer edge of the tire would graze the fender lip when the wheels where turned full left/right. A little clearing on the inside of the lip, and no more rubbing.
** The one thing you MUST check is brake hose clearance**
I have C6 brakes on it, so this may not happen with stock brakes. At full left/right, the inside edge of the rim will rub against the hose. If the hose is rubber, the wheel will make short work of it. I run stainless lines, which won't wear thru very quickly, but to be safe I made a bracket with a small extension spring to keep the line outa the way.
Old Jul 10, 2009 | 10:53 PM
Bonnetts02Vette's Avatar
Bonnetts02Vette
i have a set of Y2K highly polished thinspokes that i had widened to 18x12 if any of you are interested. 550 shipped
To Run rear 18" on the front?
