Windshield Cowl gap
Old Jul 12, 2009 | 02:36 PM
av8or's Avatar
av8or
Default Windshield Cowl gap
Just noticed that the black plastic windshield cowl has a gap between it and the windshield...right at the little tower that the wiper rests on when idle. Is this a potential interior leak problem? Thanks.
Old Jul 12, 2009 | 10:35 PM
Choreo's Avatar
Choreo
No, it will not cause an interior leak by itself unless your udders are clogged maybe. The cowl is not necessarily a water tight seal to begin with. If you gap is on the driver's side, most likely the cowl tab has broken off - for some reason they positioned that tab at the same location as the windshield tab there. I have seen several broken for that reason.
