ABS / Traction control Faults
Old Jul 14, 2009 | 09:56 AM
weinerschizel's Avatar
weinerschizel
Default ABS / Traction control Faults
This sucks... I went drag racing for my first time ever. On the first run I had HORRIBLE wheel hop. Noticed ABS light went off on dash. I restarted car to make sure it wasn't a fluke and it went away.
Well yesterday I was out crusing around and ABS + traction control light go off on the dash. I think I may have jarked something loose in that launch.
Anybody have a clue what it is where it's at? Is it the wheel speed sensors at each tire? I need to get under there and have a look but any advice beforehand would be greatly appreciated.
Thanks!
Old Jul 14, 2009 | 10:22 AM
dougbfresh's Avatar
dougbfresh
Dump the codes from the DIC and post them.
Old Jul 14, 2009 | 10:26 AM
trussme's Avatar
trussme
Default here's how to get codes...
with the key in the on position, but the engine not running
push and release the reset button until all messages cleared
next push and HOLD button #4
next push and release button #1 four times while holding button #4
When first engaged the on-board diagnostics go into an "automatic" mode which shows all parameters: PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA. If there are no problems, you will see "no more codes" on the ICP display. The computer will show two kinds of codes, "current" and "history," designated "C" or "H". A current code indicates a malfunction is present in the system whose module is displaying data. A history code indicates a past problem. When the screen displays "manual diagnostics," select the desired module by pressing the "options" button to go forward or the "trip" button to go back. Press "gages" to go forward or "fuel" to go back. To exit the diagnostic mode at any time, press "E/M".
If you want to erase or "clear" codes, press .""reset
Old Jul 17, 2009 | 07:51 PM
weinerschizel
Here's the codes I'm getting:
----BO-RFA
U1096 H
U1064 H
U1016 H
C2120 H C
----TRACTION
C1236 H
Thanks!!!
Old Jul 17, 2009 | 08:35 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
What year car do you have?
The only current code you're showing is for the Tire Pressure Monitoring (TPM) system, that's the C2120 code.
It sounds like you may have a loose sensor connection. First thing to do is clear all codes and see if the TCS lights stay off. If they do, it's probably a loose connection. If they come back on you can try pulling the fuses. Tell me what year car you have and I can tell you which fuses to pull.
Old Jul 17, 2009 | 08:43 PM
Bill Dearborn's Avatar
Bill Dearborn
The C1236 code indicates there is a voltage problem at the EBCTM. This could be due to insufficient battery voltage, a connection problem from the battery to the EBTCM, a poor ground or the EBTCM needs to be replaced. First thing to do is check voltage levels at the battery and in the underhood electrical center where the EBCTM gets its power from. Then check voltage level at the EBTCM connector, followed by checking the grounds at G108 (under the battery) and t G103 at the ground point on the drivers side frame rail next to the alternator.
The problem probably has nothing to do with the wheel hop. Here is the diagnostic procedure for the code (shown the best a table can be shown on the forum):
DTC C1236 Low System Supply Voltage
Circuit Description
This circuit is used to monitor the voltage level available to the EBTCM. If the voltage drops below 10.5 volts, full performance of the ABS/TCS/Active Handling (if equipped with RPO JL4) cannot be guaranteed. During ABS/TCS/Active Handling operation, there are several current requirements that will cause battery voltage to drop. Because of this, voltage is monitored prior to ABS/TCS/Active Handling operation to indicate good charging system condition and also during ABS/TCS/Active Handling operation when voltage may drop significantly.
Conditions for Setting the DTC
DTC C1236 can only be set if the vehicle's speed is greater than 8 km/h (5 mph). If both the battery and ignition voltages are less than 10.5 volts, a malfunction DTC will set.
Action Taken When the DTC Sets
ABS/TCS/Active Handling (if equipped with RPO JL4) are disabled.
  • Indicators that turn on:
    • ABS indicator
    • Car Icon (TCS indicator)
  • Messages displayed on the DIC:
    • Service ABS
    • Service Traction System
    • Service Active HNDLG (if equipped with Active Handling RPO JL4)
Conditions for Clearing the DTC
  • Condition for DTC is no longer present and Scan Tool clear DTC function is used.
  • 50 Ignition cycles have passed with no DTCs detected.
Diagnostic Aids
  • It is very important that a thorough inspection of the wiring and connectors be performed. Failure to carefully and fully inspect wiring and connectors may result in misdiagnosis, causing part replacement with reappearance of the malfunction.
  • If an intermittent malfunction exists refer to Testing for Electrical Intermittents in Wiring Systems.
  • Check for other low voltage conditions.
  • Test the charging system. Refer to Charging System Check in Engine Electrical.
  • Possible causes for DTC C1236 to set:
    • Charging System Malfunction.
    • Excessive Battery Draw.
    • Weak Battery.
    • Faulty system ground.
Test Description
The numbers below refer to step numbers on the diagnostic table.
4. Checks for a good ground.
6. Checks for battery voltage.
DTC C1236 Low System Voltage
Step
Action
Value(s)
Yes
No
1
Was the Diagnostic System Check performed?
Go to Step 2
Go to Diagnostic System Check - ABS
2
Check the charging system. Refer to Charging System Check in Engine Electrical.
Is the Charging System OK?
Go to Step 3
Go to Battery Common Causes of Failure in Engine Electrical
3
  1. Turn the ignition switch to the OFF position.
  2. Disconnect the EBTCM harness connector and inspect both the harness connector and the EBTCM connector for signs of corrosion or damage.
Is their evidence of any corrosion or damage?
Go to Step 7
Go to Step 4
4
  1. Install J 39700 Universal Pinout Box using J 39700-25 cable adapter between the EBTCM harness connector and the EBTCM.
  2. Using J 39200 DMM measure the resistance between terminal B of J 39700 and a good ground.
Is the resistance within the range specified in the value(s) column?
0-2ohms
Go to Step 5
Go to Step 8
5
Measure the voltage between terminals D and B of J 39700 .
Is the voltage within the range specified in the value(s) column?
Above 10.5 V
Go to Step 6
Go to Voltmeter Displays High or Low in Engine Electrical
6
  1. Turn the ignition switch to the ON position, engine off.
  2. Measure the voltage at terminals A and B of J 39700 .
Above 10.5 V
Go to Step 9
7
Repair as necessary
Is the repair complete?
8
Repair open or high resistance in CKT 1251. Refer to Wiring Repairs in Wiring Systems.
9
Replace the EBTCM. Refer to Electronic Brake Control Module (EBCM) Replacement .
Is the replacement complete?
Bill
Old Jul 17, 2009 | 09:32 PM
weinerschizel
It's a 1999 FRC... Hey guys thanks for the help!
Old Jul 17, 2009 | 09:49 PM
turnleft's Avatar
turnleft
I have been getting the same lights when I hit a large expansion joint in the highway or the seam where they are paving. Usaully just pulling over and shutting down the car will clear it. Now I have something to look for. It is a 2K coupe.
Old Jul 17, 2009 | 10:16 PM
Mark C5's Avatar
Mark C5
I know this makes no sense but it cleared a similar problem for me. Pull the 10A ABSTRNS and 20A ABS/RTDELEC fuses in the fuse panel under the hood and reinstall them if good. Clear your codes and start the car. If it wouked you TC and ABS lights will be out.
Old Jul 20, 2009 | 12:19 PM
weinerschizel
Yeah I think I may have ripped up some of the electrical connections / sensors in the launch. It was REALLY violent. I too can clear the fault by restarting the car. However, it always seems to reappear when I hit a bump in the road or something like that.
Does anybody know where these sensors are located? Are they on the rear uprights near the hubs? Or closer to the half shafts / diff? Or on the tranny?
Old Jan 30, 2011 | 03:30 PM
tb30570's Avatar
tb30570
I have this problem too (with the traction control / ABS).
Also, my fuel gauge will sometimes drop to empty when under a quarter tank.
Also, my column lock light comes on.
Also, my battery drains really fast unless you drive the car often. I've gone through a lot battery's.
Any ideas? Grounding issues?
Old Jan 30, 2011 | 06:00 PM
seoulbrooks's Avatar
seoulbrooks
Follow what Bill said above. You probably have a bad connection on the B+ or ground lug. It is not a sensor with it throwing that code.
To ABS / Traction control Faults
