Completely swapping headlight assemblies
Old Jul 14, 2009 | 04:52 PM
Slowvette002's Avatar
Slowvette002
Default Completely swapping headlight assemblies
I have a 2000/a4.
Like I mentioned, I'm about to do a complete headlight swap. Both of mine have become junk so I'm replacing them with the original factory headlight assemblies. Anyways, I know when your simply swapping its pretty straight forward, but I was wondering if anyone knew of any links to the install or any write ups at all so I can make sure I'm doing it right. Thanks ahead of time for any help guys
Old Jul 14, 2009 | 09:20 PM
Slowvette002
ttt
Old Jul 14, 2009 | 09:33 PM
byronhunter's Avatar
byronhunter
It's long, and from the manual
Headlamp Replacement
Removal Procedure
Remove the passenger side front floor kick up panel to access the IP electrical center.
Remove the cover from the IP electrical center.
Remove the HDLP Maxi circuit breaker #54, from the IP electrical center.
Raise the hood.
Disconnect the headlamp wiring harness electrical connector from the forward lamp wiring harness.
Remove the headlamp actuator **** cover.
Raise the headlamp by turning the headlamp motor/actuator manual control **** counterclockwise.
Remove the headlamp bezel. Refer to Headlamp Bezel Replacement .
Notice
When removing body panels, apply tape to corners of panel and adjacent surfaces to help prevent paint damage.
Apply tape to the fender and hood edge to protect the paint.
Remove the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Remove the brake caliper cooling duct. Refer to Brake Caliper Cooling Duct Replacement - Front in Bumpers.
Disconnect the electrical connectors from the headlamp automatic control module, RH side only.
Important
Before removing the fasteners, support the headlamp assembly.
Remove the headlamp bracket to the frame rail bolts.
Important
The headlamp assembly will have to clear the studs extending from the headlamp stud plate.
Remove the headlamp bracket nuts from the headlamp stud plate.
Lift the headlamp assembly out of the vehicle.
Remove the headlamp intermediate bracket from the headlamp. Refer to Headlamp Intermediate Bracket Replacement .
Remove the headlamp motor/actuator from the headlamp. Refer to Headlamp Motor/Actuator Replacement .
Remove the headlamp capsule from the headlamp. Refer to Headlamp Capsule Replacement .
Installation Procedure
Install the headlamp capsule to the headlamp. Refer to Headlamp Capsule Replacement .
Install the headlamp motor/actuator to the headlamp. Refer to Headlamp Motor/Actuator Replacement .
Install the headlamp intermediate bracket to the headlamp. Refer to Headlamp Intermediate Bracket Replacement .
Position the headlamp assembly onto the studs extending from the headlamp stud plate.
Loosely install the headlamp bracket to the headlamp stud plate nuts.
Install the headlamp bracket to the frame rail bolts.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Beginning with the upper location, tighten the headlamp bracket to the frame rail bolts. Tighten
Tighten the headlamp mounting bolts to 20 N·m (15 lb ft).
Beginning with the upper inner location, tighten the headlamp to stud plate nuts. Tighten
Tighten the headlamp mounting nuts to 10 N·m (89 lb in).
Connect the electrical connectors to the headlamp automatic control module, RH side.
Install the brake caliper cooling duct. Refer to Brake Caliper Cooling Duct Replacement - Front in Bumpers.
Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Install the headlamp bezel. Refer to Headlamp Bezel Replacement .
Connect the headlamp wiring harness electrical connector to the forward lamp wiring harness.
Rotate the headlamp motor/actuator manual control **** clockwise to lower the headlamp.
Install the headlamp motor/actuator **** cover.
Remove the protective tape installed during removal of the headlamp.
Close the hood.
Install the HDLP Maxi circuit breaker #54 into the IP electrical center.
Install the cover to the IP electrical center.
Install the floor kick up panel.
Check the alignment of the headlamp opening door. Refer to Headlamp Opening Door Adjustment .
Check and adjust headlamp aim as necessary. Refer to Headlamp Aiming .
Old Jul 14, 2009 | 09:50 PM
Slowvette002
wow, that is alot of steps, lol.. I knew it couldnt be as easy as it looked.. thanks alot man!
Removal Procedure
Raise the hood.
Notice
Important
Important
Notice
Close the hood.
Old Jul 14, 2009 | 10:39 PM
byronhunter
Not as complicated as it sounds.
To Completely swapping headlight assemblies
