Rearview mirror wires
Old Jul 14, 2009 | 07:14 PM
j84buick's Avatar
j84buick
Default Rearview mirror wires
Two Orange, 1 brown and 1 black. One know the real story of what they are?
1 Orange looks like +12 constant.
The other orange looks like it's +12 with the door open (dome light circuit?)
The black and brown are (-) all the time from what I can tell.
Does anyone have the real story? I have the service manuals but I lost my decoder ring. I am trying to setup an aftermarket rear view mirror.
Old Jul 14, 2009 | 07:28 PM
Its_Go_Time's Avatar
Its_Go_Time
Right from the manual:
Pin 1, brown Ignition 3 voltage
Pin 2, black Ground
Pin 6, Orange Battery positive voltage
Pin 7, Orange Battery positive voltage
Old Jul 14, 2009 | 07:39 PM
LoneStarFRC's Avatar
LoneStarFRC
Pin 2, black Ground
Pin 6? Pin 7? I think he's only got 4 pins. A,B,C and D. Not everyone has the electrochromic mirror.
I think the brown is the feed for the yellow led light.
Old Jul 14, 2009 | 07:41 PM
byronhunter's Avatar
byronhunter
What year, and which mirror the car came equiped with is important.
Edit: I agree with LoneStarFRC.
Old Jul 14, 2009 | 07:50 PM
Its_Go_Time
True dat.
Old Jul 14, 2009 | 08:04 PM
lucky131969's Avatar
lucky131969
You are slackin bro, no diagrams posted yet?
Old Jul 14, 2009 | 08:13 PM
Its_Go_Time
For my '02 WITH electrochromatic mirror, Pin 1 brown is in fact for the orange flood LED. It's hot when the ignition is in the on position. Pin 6 /7 orange is for the two dome lights. 6 is hot all the time to the dome light switches, 7 is controlled by the BCM...when you open the door, or unlock the car, it goes hot. Pin 2 black is ground for the entire mirror.
Old Jul 14, 2009 | 08:53 PM
j84buick's Avatar
j84buick
Sorry guys... its a 2000 before the fancy mirror.
Old Jul 14, 2009 | 09:00 PM
byronhunter
Hey Lucky, I just figured you'd beat me to it! But I can do it!
Old Jul 14, 2009 | 09:32 PM
j84buick's Avatar
j84buick
Thanks but I have a service manual with this exact picture. I was looking at it but I don't know how to read it.
Is the BRN a - or +? Is the ORG +12 switched? How does one tell from this picture?
From my tester the BRN and BLK are (-) all the time (makes no sense to me). One ORG is constant, the other is +12 when the dome lights are on. My mirror wants (-) when the dome light is on so I guess I have to wire up a relay.
Old Jul 14, 2009 | 09:37 PM
byronhunter
Tell us what you are needing/looking for.
Brown is 12V when Park or Headlamps are on.
There is no switched Neg. in it.
"C" circuit #150 is ground all the time.
Old Jul 15, 2009 | 04:23 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Black = Ground
Brown = Hot from the headlights
Orange 1 = Hot all the time
Orange 2 = Hot from the door switch
Old Jul 15, 2009 | 06:03 AM
LoneStarFRC
Originally Posted by tstar
Black = Ground
Is Orange 1 "A" and Orange 2 "B"? On that particular connector, GM uses letters for identification.
Old Jul 15, 2009 | 11:14 AM
byronhunter
"B" is Monitored Lamp Mini Fuse #2. (leave doors open, cuts off after a few minutes)
Old Jul 15, 2009 | 03:20 PM
tstar's Avatar
tstar
Sorry about that... Orange "1" is pin A and Orange "2" is pin B...
Brown, Headlight switch feed is pin D and Black, Ground is Pin C
I retrofitted an Auto Dimmer in my 99 which had the base mirror. Fun stuff!
Tim
Old Jul 15, 2009 | 03:31 PM
LoneStarFRC
Tim
Thanks, I figgered that's the case.
I was recently going to try and use one of those circuits for my V1 and finally decided to hard wire the power source down to the foot well fuse panel instead. Since I ALWAYS disconnect and store my V1 EVERY time I park overnight, etc. I came up with a way to make a "patch cord" to connect into my V1 since the lock tab on those damn plastic RJ11 connector ends always eventually break off. Ever try to find a female RJ11 panel socket that's small? It ain't easy let me tell you.
Old Jul 15, 2009 | 03:36 PM
tstar's Avatar
tstar
You should post that up!
The V1 uses a telephone plug??? That's kinda ghetto isn't it?
Tim
To Rearview mirror wires
Old Jul 15, 2009 | 03:47 PM
LoneStarFRC
Tim
No, not really. The V1s have used an RJ11 connector since the very beginning. Cheap, very easy to find and easy to make one yourself if needed.
Seems like there's another company that uses them too. Can't recall.
Old Aug 18, 2009 | 08:05 PM
mickey_7106's Avatar
mickey_7106
i was wondering what to hook up my home made invisicord to
Old Aug 18, 2009 | 08:10 PM
mickey_7106
According to this website http://www.invisicord.com/docs/quickconnect.pdf i need to plug in to the Brown and 2nd orange. my car is a '00 with out autodim so should i plug in to 1st Orange and black?
