any corvette mechanics here? please step inside.
Old Jul 15, 2009 | 12:27 AM
01Z516SPD's Avatar
01Z516SPD
Default any corvette mechanics here? please step inside.
thanks for looking. Im trying to sell my vette and I have two small issues and would like to get a price esstimate from somebody that actually runns a shop if possible or at least is sure about the price of my repairs.
1. Driver side down control of passanger window not working, all other controls work fine. im told its just a relay?
2. service traction control/ABS warning lights are on. I was told the EBCM needs to be replaced or repaired.
Any idea of what it would cost to get these two items repaired at a reputable shop? Feel free to PM me a response if necessary.
Thanks Again
Gene
Old Jul 15, 2009 | 01:20 AM
skydive120's Avatar
skydive120
On the first poblem I would try swapping relays with the one from the other side, I dont know what the location is or what part numbers they are though. Relays are not hard to swap or that expensive in my experiences.
Wish I could help more but both are new to me.
Chris
Old Jul 15, 2009 | 11:41 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
About $20 parts on both, maybe a few hours labor
absfixer resolders the white relay
the door modules often have relay failures
I posted this in your ad
Old Jul 15, 2009 | 12:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You may NOT need a EBTCM!! What DTCs are you seeing for the EBTCM??? Please read and post the DTCs. If you have NOT read the codes before, there may be A LOT of old history DTCs. CLEAR them and drive the car until the problem comes back and THEN read and post those DTCs.
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Old Jul 15, 2009 | 12:38 PM
Tech's Avatar
Tech
To any corvette mechanics here? please step inside.
