I've got a 98 Auto with about 110,000 miles. Put a set of Long tubes on and a new cat back. it already has a under drive pulley and cold air intake. I'm wanting to put a LG G5X3 in it. I know ill need new push rods... But what size???. and some new springs...a new timing chain...and gonna go ahead an get a new oil pump. what else will i need or should i go ahead and get. Do i need lifters...rockers...new valves??? I plan on having a local shop do the work. Advice is much need and i'm open to all opinions.
I would go with new lifters and trays.....but that will mean pulling the heads! Should measure for pushrods with a pushrod length checker. Don't just get a timing chain, get a complete new timing set with cam & crank sprockets.
So if i get new lifters should i get OEM stock lifters or a better aftermarket lifter. And are the stock rocker arms adjustable? Some after market lifters say ill need a adjustable valve train...
Your best bet is probably LS7 lifters which will be fine for your setup. If you want the best and are willing to pay $500 you can get some Morels. Haven't heard that you need an adjustable valve train. I know I don't on my Morels!
Alright well thanks that helps. can i use 3/8 push rods or just 5/16 push rods ?
You can probably get 5/16 hardened pushrods. Some guys have used 11/32 but not sure on stock heads. I have 3/8 but I have TFS 215's that are machined for them.
Just get the LS7 lifters and new lifter buckets. I would get NEW Valve Seals and new GOLD Springs.
Have your rockers up-graded with improved roller bearing retainers. There are a couple companies that do that.
Get a new LS2 timing chain with BOTH gears.
You will need a new timing chain cover seal, oil pump O ring and water pump gaskets. I used a Melling pump on my 02 ZO6 and I am very happy with it.
See if you can locate a LS6 intake or a 2001 + C5 intake (same as an LS6) and install that in place of your stock intake. Much better air flow.
I would also recommend installing a Powerbond Damper.
If you remove your heads, you will need NEW head bolts (there a ONE TIME USE bolt) and head gaskets. Order the MLS Gaskets I up-graded to an ARP damper bolt.
One thing I would mention is that the G5X3 is a big donkey di(k of a cam on stock heads... You're not even shaving them to bump compression - helps with throttle response on large duration cams.
I'd get a cam in the 228 intake duration and 23x on the exhaust for a stock headed car.
ShoulD I wait and just get a new set of heads? If so which ones?
That is what I decided to do - but heads can be done later also. When you decide to do heads I would recommend TFS or AFR. There are pros and cons of doing it all at once. Pro is the labor savings and you can have heads all set up for you prior to install. Con is the significant more time & money it adds to the project!
