St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
**Offical LG GT2 Corvette Rebuild Thread**
Hi guys,
Everyone remembers the scary and horrible fire at Long Beach with Boris behind the wheel of our GT2 Corvette. I am happy to announce that the car is going back together now and will make it's first appearance at the Corvette's of Carlisle show then onto Watkins for it's first shake down runs before Atlanta.
Fire!!
Blasted and Cleaned Frame
Frame being Primed
Frame being painted
Frame complete in red
Front Suspension mounted Rear suspension going together
Center Switch panel stack Dash rebuilt and ready for install
Pedals, Steering column, and shifter being installed
Louis and myself are going at it pretty quickly now, so I will be updating the thread with new pictures as the car comes together so STAY TUNED!!!
Not too much, but we have to use a factory block with no material added, but it can be removed. Factory 823 LS3 castings ported, again, no material added but can be removed. Inlet manifold is open, so we run a mechanical Individual Throttle Body setup, but we are capped to 2 29.6mm restrictors. A little larger than the size of a quarter.
We use a Callies crank, specially made for us. It must be within 10% of the factory crank weight
Rods must be ferrous, and pistons must have 3 rings. Other than that, its pretty much free.
Total cost of engine, dyno tested and supplied with a harness and proprietary calibration is a tick over 70K
Originally Posted by 95BlueBomber
This is a cool thread!
Whats the pump at the lower passenger side of the engine? Oil? I would assume this is a dry sump
That it is, that is the dry sump pump. Cool little feature in that it is built into the billet pan so there are no external pan scavenge lines, it is all built into the pan/pump unit. The only external scavenge is the one from the lifter valley.
