Using the GM upper engine cleaner
Old Jul 18, 2009 | 12:25 AM
lp2k's Avatar
lp2k
Default Using the GM upper engine cleaner
Hello , there was a thread about using the GM upper engine cleaner with some photos on where it was to be poured in via afunnel and to use 2 bottles, where is this thread or the photos? i have searched and had no luck
thanks everyone!
Old Jul 18, 2009 | 09:52 AM
JCamaro's Avatar
JCamaro
Seafoam works very well to clean your intake and cylinders, do a search on here, lots of people have used it (me included) and they swear by it.
It goes in thru the brake booster vacuum line.
Best of luck,
JC
You would probably use the GM top end cleaner in the same manor as seafoam.
