Stroker kit recommendations
Old Jul 18, 2009 | 08:27 AM
4GTABODT's Avatar
4GTABODT
From: Mississauga, Ontario Corvettes were built to be driven...not trailered
St Jude Donor '07-'08-'09
Default Stroker kit recommendations
As some of you know, I have been toying with the concept of going FI on the car...but all the research I did suggested that even though stock bottem ends on an LS1 "can" handle 500-550rwhp, the bottom end becomes the weak link. Read enough stories on here of engines breaking after an FI system was installed (Ya, I know many of you have had them installed and have had no issues, so lets not make this a debate for the purposes of this thread)
So, I've decided that before I go FI (haven't fully decided on turbo or S/C), I want the bottom end of the motor to be bullet proof (or at least a heck of a lot stronger than it is now). SInce I'd been re-dong the bottom end, decided I'd stroke it at the same time (get your minds out of the gutter)
If you search the web or that common auction site, there are 100's of 383 stroker kits. So the question becomes....which one to get?
Just wondering what kits some of you guys have used and also any suggestions
Thanks guys
Mo
Old Jul 18, 2009 | 04:18 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I wouldn't waste my money on a 383. For a few extra $$$'s you can get a 402 or larger. I have a 383 in my car, and I regret not spending the extra couple hundred bucks.
Old Jul 18, 2009 | 05:47 PM
chevylad's Avatar
chevylad
I'd just go for the whole short block. You can't just bore the block out like the old days. I like the prices at TSP.
Old Jul 18, 2009 | 07:01 PM
AU N EGL's Avatar
AU N EGL
whole new 402 short block for best use of time and money
Old Jul 21, 2009 | 03:36 PM
Matt@Texas-Speed's Avatar
Matt@Texas-Speed
Premium Supporting Vendor
Thanks for the referrals guys! Give us a shout and we can get you setup with a stroker that will make the power you're wanting without breaking the bank! We've got a pretty nice assortment of 402, 408, 418, and 427's on the shelf ready to go also, so we might be able to get you taken care of without the huge wait times too
__________________
Largest Stocking Distributor of LS-x Engines / Largest LS-x Comp Cams Distributor in the Country!
COMP - FAST - PACESETTER - CALLIES - COMETIC GASKETS - MONSTER CLUTCHES - MOSER ENGINEERING - KOOKS
ARP - GM BOLTS AND GASKETS - MSD - NGK - POWERBOND - WISECO - ASP - AND MORE!
Old Jul 21, 2009 | 03:48 PM
Tech's Avatar
Tech
402 = new heads = new intake = new throttle body. A nice forged 347 with ported 243 heads might get the job done for you. If you're going to boost it anyway, who cares about cubes?
Old Jul 30, 2009 | 10:58 PM
JnJSpdShop's Avatar
JnJSpdShop
Old Aug 7, 2009 | 08:51 PM
cdn ws6's Avatar
cdn ws6
One guy to talk to in your area, Arun!
Old Aug 7, 2009 | 09:17 PM
WKMCD's Avatar
WKMCD
Arun at Champion is a great guy and should be relatively close by.
To Stroker kit recommendations
