Lowest lowering bolt kit
Old Jul 18, 2009 | 05:50 PM
Torch FRC's Avatar
Torch FRC
Default Lowest lowering bolt kit
I have the WCC lowering kit and cannot get the front to sit lower than the rear. The rake is gone. I do not want to take the front bolts out. Will the Zip kit allow for the front to sit lower than the rear? Is there another option to drop the front? -Thanks
Old Jul 18, 2009 | 06:13 PM
bumble-z's Avatar
bumble-z
No it won't set any lower. Either raise the rear or take the bolts completly out in the front to get the rake. Good luck.
Old Jul 18, 2009 | 10:52 PM
txFRC's Avatar
txFRC
why cant you cut the bushing down a little bit like on the stockers?
Old Jul 18, 2009 | 11:54 PM
matt75's Avatar
matt75
the zip and all of the other kits i've seen have you cut the bushings or include bolts without bushings. I maxed out the fronts and had to raise the rear as well. Didn't want to remove the front bolts.
Old Jul 19, 2009 | 05:28 AM
bdiddo's Avatar
bdiddo
That looks pretty damn slammed as it is. Nice stance! i need to get to mine.
Old Jul 19, 2009 | 02:00 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
you need to go to coilovers
Old Jul 19, 2009 | 03:09 PM
yyukon's Avatar
yyukon
Here are your three choices. Starting at the right, Stock, Hardbar, and ZIP. 1/8" difference between Stock and Hardbar. 1/4" difference between Hardbar and ZIP.
ZIP front bolts turned all the way in and ZIP lowering bolts on rear.
Tires slightly shorter than stock. 295/30-19 Rear and 265/ 30 or 35-18 Front.
Van Steel has a new Coilover that has a good price, as coilovers go.
Last edited by yyukon; Jul 19, 2009 at 03:17 PM. Reason: WCC NOT SUPPORTING VENDER
Old Jul 19, 2009 | 05:02 PM
FKING1's Avatar
FKING1
Aren't stock bolts the left ones?
Old Jul 19, 2009 | 06:33 PM
yyukon's Avatar
yyukon
Yes you are correct. Guess I do not know my left from my right.
Old Jul 19, 2009 | 09:20 PM
Indy's Avatar
Indy
Did you cut the bushings up front? If you did, that's pretty damn low...I scrape everywhere I go...don't think the Vette would be drivable at all any lower.
Old Jul 20, 2009 | 03:50 PM
FKING1's Avatar
FKING1
Before going to coilovers I cut 1/2 off the frt bushings and the car scraped on everything. Would never go lower.
To Lowest lowering bolt kit
